Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55 to 59 chevy truck owners
  #2680 (permalink)
Old 01-19-2012, 10:31 PM
garretthes's Avatar
garretthes garretthes is offline
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
Originally Posted by ogre
the door hinge bolts are 3/8'' fine thread (3/8-24) i bought my replacements from my local home depot.
they are all relatively short, i believe 1 1/4''
if you want door switches, now is the time to add them.
here is a simple bracket i made to mount door switches in the upper hinge, using the center bolt.
the bracket is a piece of 10 ga steel, 1''x5'' with 2 holes drilled in it.
door open
door closed
I put my door switches in the normal boring spot. Also on the back doors.
The second pic is the back door. I also added a 2nd dome light in the back near the back doors.
Name:	Door Switch.jpg
ID:	62019   Click image for larger version
Name:	Door Switch 2 .jpg
