dsraven pretty well hit on all the points i would have. it's a little ghetto to run rubber that far, so much restriction that you may need to add a pump in back. change to steel line, safer and no pump needed.
the vent should be pretty much like it is. you can add a small filter there to catch any slosh or water. with your thru the bed fill and a vented cap you could plug it.
