Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55 to 59 chevy truck owners
  #23 (permalink)
Old 09-19-2006, 05:33 PM
DOUBLEDICK's Avatar
DOUBLEDICK DOUBLEDICK is offline
Wow.I was beginning to think not many guys bothered with these trucks.Thanks for all the responses.As for the name doubledick The guys at work gave me that name as a form of harassment for being a butt all the time.They have called me that for so long now some of the guys at work don't even remember my real name.58 Apache I pull a trailer with my truck all the time.I used a 68 hidden hitch receiver from brothers trucks so I can hide it behind the plate.The 87 rearend I installed has the big 11 inch drums and uses the wide brake shoes.I run a power-trax locker with 4.56 gears and 31x10.5 tires.My truck is a work truck.I split the leaf spring pack and added a heavy overload leaf on top of the straight overloads and bolted it together with a new bolt.Now if the rear squats more than an inch it is on the overload leaf.The front and rear anti-sway bars and the traction control bars keep the trailer from pushing me around.I run coil-over Edelbrock sensatrack shocks on the back and coil over shocks on the front so it wont ride like a buckboard when it is empty.I do have the front disk conversion from brothers with the vacuum booster and have no problems stopping even when I had 2700lbs of sand in my trailer.Rear disks are nice but there is a reason semi's use drum style brakes.My truck is just a 58 Chevy 3100 but it weighs 6000lbs empty so a heavy trailer is not a problem,I just have to have a balanced trailer with very little tongue weight.You shouldn't have any trouble with a 1 ton suspension stock or modern.Your options are unlimited.A tape measure and a trip to the wrecking yard will help you find what you are looking for.Good hunting my friend.
Name:	100_0060 (600 x 450).jpg
