Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55 to 59 chevy truck owners
  #25 (permalink)
Old 09-19-2006, 06:17 PM
DOUBLEDICK's Avatar
DOUBLEDICK DOUBLEDICK is offline
Wills36 that is quite the journal. Gator412 I was checking out your journal and noticed you don't have a sway bar on the front.The one from brothers trucks works great.You just have to make better mounts. the angle iron under oneside of the U-bolt was sad to say the least. I posted some pictures of the ones I made.I made them out of 1/2 inch plate steel and counter sunk the holes both sides with a 3/4 inch drill bit for the lip on the rubber parts to set down into so they stay centered..I also put in shorter bolts and cut down the spacer to level off the sway-bar.I used brother trucks rear sway bar and traction bars too.I made heavy duty front mounts for the traction bars as I broke the one that came with the kit.Mine are made of 1/4 inch plate for the mount welded onto a 3/8 plate steel backing.I also made front shock mounts out of 1/2 plate steel because the coil-over shocks were too much for the stock mounts.I just drilled out the rivets to remove the stock mounts and traced them onto 1/2 inch plate drilled the holes then cut them out with a metal cutting blade and my skill saw.
Name:	000_0142 (600 x 450).jpg
ID:	15030   Click image for larger version
Name:	000_0141 (600 x 450).jpg
ID:	15031   Click image for larger version
Name:	000_0139 (600 x 450) (600 x 450).jpg
ID:	15032   Click image for larger version
Name:	000_0138 (600 x 450).jpg
ID:	15033   Click image for larger version
Name:	000_0111 (600 x 450).jpg
