Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55 to 59 chevy truck owners
  #161 (permalink)
Old 12-04-2006, 02:42 PM
DOUBLEDICK's Avatar
DOUBLEDICK DOUBLEDICK is offline
hotrodsbyray These pictures should help you.the first picture is the stock mount I used for a pattern.The second picture is the new mounts.you cant see it but the bottom bolt hole has been recessed into the mount and a carriage bolt is in the hole.the top two are grade 8 bolts.The third picture is the shock mounted on the new top mount and the stock bottom mount.The fourth picture is the drivers side.The driver side mount is in the stock bottom bolt hole but the top has been shifted forward(about 1/4 inch)to allow clearance for the steering arm.
Name:	101_1540 (600 x 450).jpg
ID:	16616   Click image for larger version
Name:	101_1537 (600 x 450).jpg
ID:	16617   Click image for larger version
Name:	101_1539 (600 x 450).jpg
ID:	16618   Click image for larger version
Name:	101_1541 (600 x 450).jpg
