Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55 to 59 chevy truck owners
  #506 (permalink)
Old 03-05-2007, 10:28 AM
DOUBLEDICK's Avatar
DOUBLEDICK DOUBLEDICK is offline
Here is a picture of the Clear Gears cover.The cracks go all the way around.I also posted pictures of the sway bar now that it is turned around.Wow Gator that is the way to work on the truck.No dirt falling in your eyes,no dropped wrenches bouncing off your fore head,no brake fluid in your face and no metal pieces in your shorts from using the drill under the truck.Dave I think Gator just doesn't like having as much fun as we do Gator on that ford 9 inch rearend you have how wide 2 or 2 1/2 and how big are the drums 10 inch or 11 inch.Did you measure across the bed to see how wide it is between the wheel wells.On my 58 an inch wider worked fine an inch narrower would have put my tires 1/8 inch from the bed
Name:	000_0204 (600 x 450).jpg
ID:	19136   Click image for larger version
Name:	000_0205 (600 x 450).jpg
ID:	19137   Click image for larger version
Name:	000_0206 (600 x 450).jpg
ID:	19138   Click image for larger version
Name:	000_0211 (600 x 450).jpg
