King pins
I am trying to find the dimensions for the king pins I was told they came from a 57 Chevy truck. Any help would be greatly appreciated.I am working on a 32 Chevy that was modified in the 80's and am trying to I.D. the spindles they used so I can replace the pins and bushings.
wiring harness
I spent a lot of time wiring the harnesses together from the Avalanche engine and the Camaro. I also had to wire in the stand alone for the fuses and relays. I think the next time I try such a project, I will try and buy the entire vehicle and scab the entire system into the project vehicle. After I bought the engine and transmission, I went back to buy the rest of the harness and they wanted $500 for it. I decided against this and went ahead with the Camaro harness. They also sold me a 2002 engine, but gave me the ECU from a 2003 or later vehicle. This caused me untold hours of troubleshooting because the throttle control for the drive by wire was different in the 2002 and I couldn't get the accelerator to work. I bought a throttle control from a 2005 and this fixed my problem. If I had bought the entire system, or vehicle, I would have avoided problems like this.
Caddie Northstar
BMAR- Saw a video of the building of the HotWheels Deora-2. They used a Cadillac Northstar engine the power the thing. (It's nice to have GM as a build buddy) Same sort of nightmare, and they ended up using all of the original harness just to get it to work. With all of that they ended up missing a rear impact sensor, which kept the engine from firing. Took a while to figure it out. I think you can get a custom harness now to do the same thing. Not cheap, but probably worth it.
wiring harness
I also looked at the various aftermarket harnesses and they were not cheap. I also remember there still being quite a bit of soldering required to install the harness to the application I would need. I think the aftermarket harness would be easier, but the initial cost still made the factory harness a viable option. I would have saved a lot of time by having the original firewall connectors for the transition from the engine to the cab. My way required cutting off the factory connector and soldering on the Camaro firewall plug. Next time I will be buying the entire harness, front to back, and installing everything as a single unit. Bill
Corvette LS engine
I must be a glutton for punishment. Once I finish the truck, I would like to pull the engine and transmission from my Corvette and drop in an LS engine/transmission. I guess I didn't learn the first time. I know I really enjoy the vehicles I have driven that have LS technology, and the added bonus of excellent gas mileage is all the better.
fuel tank
Has anybody tried one of the fuel tanks from chevy's of the 40's? Their ad says the size is 28 by 20 and they have a fitting for EFI. There are two styles I am looking at. Thanks Bill
http://www.chevsofthe40s.com/detail/...PROVISION.html http://www.chevsofthe40s.com/detail/...INJECTION.html |
EFI fuel tank
My main concern is how big the opening is for the fuel pump. I already have the fuel pump from the Avalanche engine wired in and I am using it inside the Camaro gas tank. I had to cut an opening in the Camaro tank, and I would rather not have to cut the replacement tank. I also don't want to buy another fuel pump and wire it into the harness.
fuel tank width
Gene, The width of 20 inches may require some fitting, but the length shouldn't be a problem. Bill
Hey , Bmar
I was looking at your project journal and did you start your pickup project with those 3 pickups you trailered home in pieces ???? WOW, What a way to start a project. While I was looking at your journal I had a few thoughts and questions. If you don't mind me asking? Why you mounted the rearend to the springs the way you did instead of cutting off the spring pad and rewelding them to the axle housing under your springs? I also noticed that you moved the axle to the above the spring location instead of under the spring, and the chassis is on jack stands. Are you going to C notch and box the frame above the rearend for axle housing clearance? Also with the weight of the truck on the springs it looks like the center of the rearend will hit the box tube crossmember you put in for your shocks. Just a few thoughts I had looking at your journal. Gene |
57 apache???
i was watching barret jackson last nite.
they sold a sweet 57 custom for $30k. funny thing is they sold it as a 57 apache, it had 58 trim on the 57 front clip first time i ever heard of a 57 apache apache badge was 58 thru 61(?) only |
I know what you mean I've seen them on Barrett Jackson and they always get something wrong on the trucks . Maybe they are wrong on the cars too but I just don't know enough about them to tell. I ordered the one piece glass kit from brothers last week . So maybe I will receive it next month. Its on back order also. Every time I order something from them It's backordered. But everything I've gotten from them has been good quality though. I guess I just get anxious. Speaking of anxious my wife is having our third baby on the 23 of this month. I will be busy for a while. I just pray all goes well. I stay real busy now going back to college and being a dady again . I'm going to the autorama in dallas this weekend though .
I got my new Street Rodder magazine yesterday and saw an ad for Street Rod Headquarters and they are selling a complete new steel cabs with doors from Dynacorn for 55,56 and 57 Chevy pickups. I checked out their web site and they sell for $8,995.00. And weigh 650 pounds. Wow a big crate and truck freight , that could be big $$$$$$$'s.
I guess that could be better than some of the rusted out old cabs we have to work with. Gene http://www.streetrodhq.com/detail/32...INSTALLED.html |
| Recent Hotrodders' Lounge posts with photos |
| 1953 Chevy Truck Vin Help | Homeseller | Hotrodding Basics | 14 | 08-12-2012 09:24 AM |
| Mustang 2 Front end on a 55 Chevy truck? | Slickriffs | Suspension - Brakes - Steering | 14 | 11-10-2010 06:10 PM |
| 55 chevy truck rear end swap | Wildman | Transmission - Rearend | 8 | 06-11-2007 07:16 PM |
| 47-54 Chevy truck owners need a quick simple measurement | sevt_chevelle | Body - Exterior | 2 | 06-18-2006 10:32 AM |
| nova subframe on a 59 chevy truck | bet on black | Suspension - Brakes - Steering | 3 | 01-27-2005 08:48 PM |
