55 to 59 chevy truck owners - Page 114 - Hot Rod Forum : Hotrodders Bulletin Board
  #1696 (permalink)
Old 03-26-2010, 09:28 AM
Rusty59's Avatar
Last journal entry: Drop axle install
Blazer gas tank
Shadetree-thanks for the info on the Chevy gas tank. I have the same one, (but a little beat up on the bottom) that I'm going to use in my '59. Mine came out of a full size GMC van, so I think they must have used them in several models.
  #1697 (permalink)
Old 04-08-2010, 09:14 AM
57halfton's Avatar
Hey, where did everybody go ? Must be out working on your trucks instead of surfing the web.
Gene
  #1698 (permalink)
Old 04-08-2010, 06:25 PM
ShadetreeTim's Avatar
Another transplanted Okie
Last journal entry: DMV Trip
Iíve been thinking the same thing Gene. The past two weekends I have been too busy with family in from out of town. Haven't had much time to work on the truck. I did manage to weld the stake pockets back on the front of my shortened bed. I welded through the holes I drilled to release the original spot welds. Still need to grind the welds smooth. And I installed my new rear window. 10 years ago I had reinstalled my original rear window and swore to never do it again. So the other day I called a local classic auto-glass company about installing it. The guy proceeded to bash my purchase of window and rubber from Brothers, claiming he always has to modify their windows to make them fit and their rubber is too large?!? I never appreciate anyone who badmouths another's products to convince me their own is better. He thoroughly inspired me to install this one just to prove him wrong. It went in way easier than I remembered and fits great right out of the box. Thanks "bad phone sales guy", you just saved me some money. On a different note, I've been looking for John Deere Blitz Black paint to use on my inner fenderwells and suspension pieces. My local JD Dealer doesnít keep it in stock. Last week I went up to Santa Maria for work and the JD Dealer there has lots of Quarts, Gallons and Spray Cans on their shelves. I wish I had more to report as my to-do list doesn't seem to be shrinking very fast. I'm taking a vow right now to concentrate on the mechanicals from now on until it's drivable.
ID:	45017   Click image for larger version
ID:	45018   Click image for larger version
  #1699 (permalink)
Old 04-08-2010, 09:41 PM
merlinsoars's Avatar
Sin Vertis Stratio
Well Ive been diligently going thru the whole brake system on my 59, decided on all new everything including the brake lines.. thats been hit and miss tho as the paying work is picking up. Off to the Del Mar show tomorrow afternoon after i visit two of my job sites in SD county. Back to the truck on Saturday
Keep 'em rolling
  #1700 (permalink)
Old 04-09-2010, 05:05 AM
Lil John's Avatar
Wanabe Mechanic
Last journal entry: 55 chevy 2nd series truck
Shadetree did you install the big back glass alone? I will try this hopefully soon . Maybe my wife will help some.
  #1701 (permalink)
Old 04-09-2010, 08:00 AM
57halfton's Avatar
I have done several windshields but not a back window. Last time I did one my wife and daughter helped, they were on the outside gently pushing while I was on the inside pulling the cord to seat the rubber. Some extra hands outside never hurts, last thing you want is for it to fall out and break.
Iv'e been working on my other cab thats in my back yard. Im attempting to fill the open hole on the inside roof where the headliner goes and weld up and mold smooth all the spot weld seams inside. I had some rust issues on the roof skin and around the drip rails so I cut it off and got a new roof skin. I trimmed down the old roof skin to use as a filler for the inside hole. If this works the inside will be nice and smooth and painted.
I'll take some pics and try to figure out how to post them here.
Gene
  #1702 (permalink)
Old 04-09-2010, 03:29 PM
Lil John, I installed the front and rear glass alone. I used the string method halfton mentioned. I taped the rubber to the windshield with string installed. Sat the window onto the bottom rail, sprayed the area I was working on with soapy water, and pulled the string while pushing gently on the outside with my free hand. I alternated from side to side every 6-12 inches. With that being said, it would have probably been easier with a helper. For me, the lock bead was the difficult part. Tedious. I bought the lock bead install tool Brothers promotes. Looks good on my bench... It turned out to be easier with 2 small screwdrivers.
Halfton, that's an ambitious project you're doing, hope to see some pictures.
  #1703 (permalink)
Old 04-10-2010, 08:48 PM
Family's gone, let the work begin
I got a little bit done today. Nice to be back out on the side of the house for an entire day. I decided to narrow my Ranger differential since it may be awhile until I am able to get the diff I'm waiting for. Using a pre-93 right axle on the left side I was able to take 4Ē out of the width. I made some braces for the axle tubes from angle iron. Next I have to build the lower shock mounts.
Name:	159 041010.jpg
ID:	45060   Click image for larger version
Name:	162 041010.jpg
ID:	45061   Click image for larger version
Name:	164 041010.jpg
ID:	45062   Click image for larger version
Name:	166 041010.jpg
ID:	45063   Click image for larger version
Name:	171 041010.jpg
  #1704 (permalink)
Old 04-11-2010, 07:52 AM
Sin Vertis Stratio
Front Spindle disc brake question
Is there another 5 lug Hub/Brake drum out there that will fit the front spindle of the '59 straight axle??. Was talking to several of the disc brake folks at Good Guys this weekend and seem they dont make a disc brake setup for our trucks. I dont care about brackets, those are easy, could build the hubs also but I tend to scrounge first.
thanks
  #1705 (permalink)
Old 04-11-2010, 10:20 AM
57halfton's Avatar
Hey , Tim is that a mockup rearend you narrowed ? What diff. are you going to use later ?
Merlin the front hubs and drums from at 53/54 Chevrolet car and maybe earlier Chevy cars also hubs and drums from a Corvette 62 and older will bolt right on the pickup spindles.
Gene
  #1706 (permalink)
Old 04-11-2010, 12:46 PM
Yes, the Ranger diff is the one I purchased just to get the truck rolling on its new wheels. I narrowed it to gain the experience, and I may be stuck with it for a while. A friend has a 8-3/4 Mopar he's pulling out a I hope to eventually get.
Merlin, I used 54 Chevy car drums on my 50 Chevy pickup many years ago. But I don't understand your post, "they don't make a disc brake setup for our trucks"? Brothers and CPP both have a bolt on 5-lug disc brake kit for the stock axle.
Tim
  #1707 (permalink)
Old 04-11-2010, 04:33 PM
57halfton's Avatar
Tim , I have never seen anyone narrow a rearend like that before. You going to drive it like that ????????
  #1708 (permalink)
Old 04-11-2010, 06:42 PM
Absolutely, unless I get another rear end before I get the truck back on the street.
  #1709 (permalink)
Old 04-11-2010, 09:54 PM
Sin Vertis Stratio
Thanks Tim, Wilwood was one of the vendors i was talking to as i can do an unboosted set up with their goodies, i'll look into ccp and brothers
  #1710 (permalink)
Old 04-12-2010, 09:07 AM
Noob
Just found this forum, lots of good info. Working on a 57 PU hoping someday to actually drive it. The post's on installing glass were great. Ws going to sub it out but think I will give it a try now. Going to be a hot rod truck, narrowed 9", ladder bar coilover, 79 Nova front clip, BBC/turbo 400, have a ways to go, but coming along. Keep the good info coming.
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 09:24 AM
Mustang 2 Front end on a 55 Chevy truck? Slickriffs Suspension - Brakes - Steering 14 11-10-2010 06:10 PM
55 chevy truck rear end swap Wildman Transmission - Rearend 8 06-11-2007 07:16 PM
47-54 Chevy truck owners need a quick simple measurement sevt_chevelle Body - Exterior 2 06-18-2006 10:32 AM
nova subframe on a 59 chevy truck bet on black Suspension - Brakes - Steering 3 01-27-2005 08:48 PM
