55 to 59 chevy truck owners - Page 115 - Hot Rod Forum : Hotrodders Bulletin Board
  #1711 (permalink)
Old 04-12-2010, 10:43 AM
ShadetreeTim's Avatar
Another transplanted Okie
Last journal entry: DMV Trip
Sandrat57, welcome to the site. Sounds like a great project. Looking forward to seeing pictures of it.
Tim
  #1712 (permalink)
Old 04-12-2010, 02:16 PM
DOUBLEDICK's Avatar
Hi guys I have been trying to get some work done around here but it just wont stop snowing.We are supposed to get 4 inches today and another 6 inches tonight.I put up the new shop building but ran out of time before the subzero temps arrived so the concrete is not done yet.The temps get above freezing every day now but in the teens at night so I have mud about 1 foot deep right in front of the garage so I cant use the shop at all till it dries up.It has been snowing endlessly this year so I need 2 weeks of dry weather to dry the ground up enough to move the 58 around to the shop and to get the 30 foot motor home out of the garage.If I try now I will need a dozer to pull it out of the mud Maybe next month will be better.Of course I will have to fix the van and the 98 truck before I can get to the toys.I am glad to see the rest of you guys get to play with your toys It will be my turn soon
  #1713 (permalink)
Old 04-17-2010, 05:05 PM
59 chevy truck upper front shock mount..
Hi I have a 59 Chevy Truck Stepside that the driver's side upper front shock mount has broken off. I have a pic of the passenger side if someone wants to see..it's in my photo gallery. It has the 3 rivets but also has some kind of housing too. I found some on ebay that they say will fit 55-59 but it's not exactly the same as mine. Just wondering where I can find one like mine or if those other ones will work. I guess I have to drill out the old rivets and bolt the new on with Grade 8 bolt or should I weld it? Any suggestions? Thanks
  #1714 (permalink)
Old 04-17-2010, 05:17 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by sport41
Hi I have a 59 Chevy Truck Stepside that the driver's side upper front shock mount has broken off. I have a pic of the passenger side if someone wants to see..you can shoot me your email and I can show u. It has the 3 rivets but also has an upper housing. I found some on ebay that they say will fit 55-59 but it's not exactly the same as mine. Just wondering where I can find one like mine or if those other ones will work. I guess I have to drill out the old rivets and bolt the new on with Grade 8 bolt or should I weld it? Any suggestions? Thanks
Just so you know you can up-load pics to your post or start a photo gallery, It's easy step by step instructions. These guy's more then likely won't give out a email just yet.JMO
Cole
  #1715 (permalink)
Old 04-17-2010, 06:29 PM
I posted a pic of the shock mount in my photo gallery..
I am still trying to figure out how to attach the pic to my post. It says it's too big and won't do it.
  #1716 (permalink)
Old 04-17-2010, 07:55 PM
eloc431962's Avatar
Wiki Edits: 37
You know if you can't find another mount you do have one good one there to go by, I would just fab one up you have the dimensions on th other one . Just a thought.
Cole
  #1717 (permalink)
Old 04-17-2010, 08:07 PM
Fab one up..
Where can I go to get one made up if worse comes to worse and I can't find one? Also do you think there is any difference between the passenger side and driver's side? Thanks
  #1718 (permalink)
Old 04-17-2010, 11:34 PM
Hi Sport41, my 57 GMC had the front shock mounts bolted to the frame with three grade 8 bolts (until I removed them). I don't think you would need to weld them on.
The mounts are identical left and right.
I don't have any pictures of my old mounts right now. I can take some pictures tomorrow if you want. BTW, you just need to resize your pictures smaller so you can post them.
Tim
  #1719 (permalink)
Old 04-17-2010, 11:41 PM
Sport41, I just checked out your photo album. The pic of the mounts you have titled "will these work" are identical to my 57 GMC Mounts. Just bolt them to the frame with grade 8 bolts and you're good to go.
Tim
  #1720 (permalink)
Old 04-18-2010, 09:08 AM
Shock mounts
Hi Tim,
Would it be better to drill off the good one on the passenger side that I have in the pic and have both the same as pictured "will these work" like yours or does it matter if the mounts are different if I just replace the one with your type on my needed driver's side? Just wondering if it will line up the same as the other side since the mount is a bit different. Also, do you know how long of grade 8 bolts I need and do I need any washers as well? Also, would it be better to take the truck in to somewhere where they sell shocks or should I let the body shop install the mount? Thanks for the help My truck is at the body shop and just trying to get some idea what to do..
  #1721 (permalink)
Old 04-19-2010, 01:29 AM
DOUBLEDICK's Avatar
hello sport 41.I run coil over shocks on the front.I made new mounts out of 1/2 inch plate steel.Just drill off the rivets and take the old ones off.I bolted them on with grade 8 bolts left and right but for the bottom I counter sunk the hole and used a carriage bolt.I traced the stock one on 1/2 inch plate twice.I used a hand drill to pre drill the holes then cut them out with a metal cutting blade in my skill saw then rounded them off with my grinder.Here is a picture of the stock one and the new one I made.I just took the shock mount bolt off the stock one and bolted it on the new one I made .It works Great and only took a few hours to do.Give it a try it is easy.
Name:	101_1537 (600 x 450).jpg
ID:	45244   Click image for larger version
Name:	101_1540 (600 x 450).jpg
ID:	45245   Click image for larger version
Name:	101_1539 (600 x 450).jpg
  #1722 (permalink)
Old 04-19-2010, 01:47 AM
DOUBLEDICK's Avatar
sport 41 to load pictures I use pixresizer.Just google it and down load it for free.I drag and drop pictures to my desk top and resize them.I just click on load picture then click on apply recommended then click on save picture.A window will open.Click on save and it will load the resized picture on your desktop.To add the resized pictures to your post you type your message then scroll down to manage attachments and click on that.Click on browse.Upload the resized pictures off your desk top then click on upload.the picture will be added to your post.Have fun and post all the pictures you can.We love to see the pictures I hope this helped.
  #1723 (permalink)
Old 04-19-2010, 03:53 PM
Thanks
Thanks for the info on making up new ones. I will first try and see if they ones I bought on ebay will work first and go from there...
  #1724 (permalink)
Old 04-19-2010, 09:23 PM
Floor start
I have a '59 fleetside. I was with my dad when he bought it in 1974 and learned to drive in this little beast (loved the column shift).
Anyways, I want to upgrade the suspension and throw in a v8 and make it my daily driver. But one thing I want to keep is the floor start. I can't imagine this would be difficult as a starter switch is a starter switch, but before I got my hopes up of keeping it floor start, I wanted to know if anyone has kept theirs?
If I do install a V8 will there be any problems with space between the firewall and the engine/tranny if I leave the floor start?
I have a 454 right now with a 400 tranny out of an old suburban, but i think I'm gonna try and get a small block and smaller tranny.
  #1725 (permalink)
Old 04-20-2010, 12:44 PM
What type of engine is best?
I have a original 235 6 cyl in my 59 Chevy Apache Shortbed Stepside Truck 4 speed on floor.. If I did exchange the engine out of it should I go with a 327 or 350? How much would this cost for the engine and install if I had someone else do it? I heard it's not easy cause you have to do some modifications with the radiator etc. Thanks for any help....
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 09:24 AM
Mustang 2 Front end on a 55 Chevy truck? Slickriffs Suspension - Brakes - Steering 14 11-10-2010 06:10 PM
55 chevy truck rear end swap Wildman Transmission - Rearend 8 06-11-2007 07:16 PM
47-54 Chevy truck owners need a quick simple measurement sevt_chevelle Body - Exterior 2 06-18-2006 10:32 AM
nova subframe on a 59 chevy truck bet on black Suspension - Brakes - Steering 3 01-27-2005 08:48 PM
