55 to 59 chevy truck owners - Page 119 - Hot Rod Forum : Hotrodders Bulletin Board
  #1771 (permalink)
Old 05-01-2010, 10:52 AM
ogre's Avatar
the 'Duracell Project'
i re-read your post. sounds like you already have them and want install pointers.
you will re-use your bottom of your window frame. the setting tape that brothers sent did not grip the glass securely. i used windshield butyl caulk to glue in my glass instead of the tape.
buy some 1/2 inch 3M foam tape like they use for body kits http://www.autogeek.net/3m-auto-tape.html (never used this site, just for refference) home depot in our area carries the 1 inch tape, that i had to cut in half (pain). this will hold the new window sweeps in. also eliminates the little screw that they say to put in here.
also get some adhesion promoter. use this stuff and the 3m tape is permanent.
the kit comes with the window felt channel pre-bent poorly. i used a piece of 1/4'' plywood cut to the correct shape to resize and smooth out the bends.
use plenty of clear silicone to attach the felt track top and sides. you will need to reform the bend areas to eliminate open gaps at the corners. so don't glue the corners. use lots of tape to hold everything.
buy new bottom glass stop rubbers. you need to remove and reinstall. the old ones will break.
buy some black foam weather strip 3/8 wide x 3/16 thick. to go around the window felt when you install your inside trim as there will be a gap here if you don't.
  #1772 (permalink)
Old 05-01-2010, 08:57 PM
Fleetside Bed Trim
So. Finally have in my possession all of the side trim pcs for my 59 longbed fleetside. Thought that was the hard part. Now I'm trying to install them and I cannot find the right clips/fasteners anywhere! I've tried body shops, been all over the internet, the FBI knows but won't tell me...Please! if anyone even has a photo or a drawing of what they are supposed to look like, I'd be thrilled. Also, and I know this should be easy---I have new window regulators, but can't see an obvious way to replace them--help there would also be greatly appreciated. Thanks guys!
  #1773 (permalink)
Old 05-01-2010, 09:17 PM
Orge,
Thanks for the info. Love the truck! I was thinking of running a chanel in the front part of the window to give it more stability.
  #1774 (permalink)
Old 05-02-2010, 06:19 PM
Lil John's Avatar
Wanabe Mechanic
Last journal entry: 55 chevy 2nd series truck
Originally Posted by 57halfton
Thats a Chevelle 12 bolt rearend. I would say your axle tubes are leaking and it looks like someone already put some crappy welds on the tubes. I think I would clean it up and get the tubes rewelded buy a professional welder and check for straightness. Then raise the rear of your panel an inch or two. Move the upper shock mounts out some to a point where the shocks barely clear the frame rail. They are layed down to much now to do much good. The bump stops you are looking at will probably make it ride bad when you hit bumps. Or you can raise the floor inside for clearance.
Well I think thats what I'd do anyway.
Gene
Sorry to get in on the end of the thread but I have a question that goes along with this . I am trying to install some shocks on my truck . I bought a coilover shock mount kit from jegs and have been told to put the mounts in at an angle . Is this better than putting them straight up and down ? It makes sense that at an angle they wouldn't bind as much but when looking at some newer trucks they were vertcal . Does anyone have any info on this. Right now I have leaf springs that were the original ones but I have no shocks installed yet.
John
  #1775 (permalink)
Old 05-03-2010, 10:44 AM
ogre's Avatar
Originally Posted by Craig legacy
Orge,
i think the front channel needs to float to give the required 'wiggle room'
try it both ways
  #1776 (permalink)
Old 05-03-2010, 12:22 PM
55chevypanel's Avatar
radiator
I am in the process of moving and found the old brass and copper radiator from my 55 panel seems to be in good shape and it wasn't leaking when i pulled it ... think there's much interest for this ?
  #1777 (permalink)
Old 05-03-2010, 09:33 PM
ShadetreeTim's Avatar
Another transplanted Okie
Last journal entry: DMV Trip
Lil John, from what Iíve read, the reason they angle the top of the shocks in is to help control body lean. However the further you angle the shock in, the less effective the shock is for up/down control. There's probably a happy balance there somewhere. Because I had some fairly stiff, tall shocks off my 57 from its 4X4 days, I reused them by angling them from the original upper shock mounts to new brackets I bolted to the spring perches. A pretty severe angle, but the truck seems stiff using the old bounce test. I won't really know until I can drive it. If the rear is too soft, I'll move the upper mounts out to stand the shock up straighter and buy some shorter shocks.
Tim
  #1778 (permalink)
Old 05-13-2010, 10:05 PM
It's alive!
I started the truck today for the first time since December. It was cool driving into the back yard under it's own power. I'm happy; the truck steers very easy without power steering. I easily made a 3 point turn to turn around. While it was in the yard, I snapped a few pictures.
The other day I shot some satin green paint on the rear fender to check out the look. It's rough, still have to do the bodywork on the fender. I'm debating whether to paint the entire truck, or just the areas still in primer.
This was just the shot of adrenaline I needed to tackle the bodywork. Front fenders first, gotta get it street legal. Then I can pull the bed to do all the work it needs while I have some fun driving it.
Name:	213 51310.jpg
ID:	45643   Click image for larger version
Name:	214 51310.jpg
ID:	45644   Click image for larger version
Name:	215 51310.jpg
ID:	45645   Click image for larger version
Name:	219 51310.jpg
  #1779 (permalink)
Old 05-14-2010, 09:00 AM
bet on black's Avatar
hotrodder 4 life
looking good!
man i need to get back to work on my junk. i have to finish building the motor for the lightining first though...
  #1780 (permalink)
Old 05-14-2010, 09:00 PM
Hi Guys
I've been lurking on the 55-59 Truck thread about a week now reading most of the pages. Very interesting.
We have a '56 Chevy 3200 long bed 6 cyl. 4 sp. with a 30 year patina. I love this truck. Every time I drive it its a step back to a simpler time.
We also have a '56 GMC 100 Suburban Pick Up (Cameo). I bought it in '97 from a friend who rebuilt it back in the day '73-'78 before there was aftermarket parts for it.
He added a/c from a '69 Camero with only a minor mod to the case to clear the hood hinge. It'll freeze you out of the cab on a 120 degree day.
He replaced the heavily smoking 347 Pontiac v-8 with a rebuilt '60 Pontiac 389 punched out to 400 cu. in. coupled to the stock cast iron 4 sp. Hydramatic.
When I got it the chrome had gone bad, the paint was heavily oxidized , the tires were new in '73 and still had nubs. I replaced the tires & wheels, fiberglass bedsides, rechromed most of the trim, replaced the seat.
Now the latest truck project is my '57 GMC 100 Napco 4x4 long bed. I bought it to fast forward my '56 Chevy 3200 into what I thought what I wanted, a shiny high 4x4 .
Well when the wife needs a step ladder to get in & out that changed my mind.
So I have this long bed Chevy chassis out back that I stripped of just about everything riveted to it.
I took it over to the powdercoater and had them media blast it to bear metal, brought it home and hit it with 2 coats of Dupli-Color self etching primer and 2 coats of Dupli-Color semi-gloss black enamel.
Then I headed to No Limit in San Bernardino (700 miles 1 way) to have them install their Wide Ride front Suspension with air ride, 11" disc brakes, power rack and pinion and their front brake line kit.
Also had them install a Currie 9" (4.11) with their Fat Bar rear suspension and air ride.
Three days and 24 hours labor I'm heading home with a rolling chassis, aluminum 20 gal fuel tank and fuel line .
After I got home the Air Ride Kit and tanks , park brake kit, trans mount and cross member, engine mounts show up with the FedEx and UPS trucks.
The engine and trans that I WAS going to install was what I had on hand a (don't kill me) Chrysler 360 & A-500 TorqueFlite O/D Trans . I went so far as to set the trans in the chassis.
The more I thought about it the more I felt if I'm spending this kind of $ on the chassis why not update more then 20 years on the power train.
So a call to the local auto dismantler and I've got a complete 2005 Chevy 5.3 v-8 and 4L60E Trans with everything, wiring, computer, a/c,p/s,Rad.,A/C Condenser, driveshaft, gas pedal & cable. If it was attached to the engine or trans I got it all for $2500.
Now the fun begins, running brake lines,installing the P/B & M/C, installing the Air Ride lines,tanks,pump & controls,parking brake cables & levers, battery box and chassis wiring & trailer wiring.
Speaking of Trailer stuff I found U-Haul has a perfect Class III receiver that by just drilling new bolt holes fits the chassis and stock rear bumper perfectly. U-Haul Part # 75133.
Then I'll fab motor mounts and set the engine and trans and figure out what to use for headers. Then exhaust system, fuel lines, tank mount pump, EVap canister and line.
When all that's done it will be time to move the body over and hook up the steering, mount the computer and wiring, cooling system and a/c., upgrade the interior and make it run
I'm Glen and she's Rita G&R's57GMC
ID:	45655   Click image for larger version
ID:	45698   Click image for larger version
ID:	45699   Click image for larger version
ID:	45700   Click image for larger version
  #1781 (permalink)
Old 05-14-2010, 09:04 PM
Our 57 GMC Hitch
Here's the U-Haul Class III Reciver part #75133
  #1782 (permalink)
Old 05-14-2010, 09:08 PM
Our 57 tucked away
our 57 GMC
Name:	57 LF 1:4 view2.jpg
ID:	45660   Click image for larger version
ID:	45702   Click image for larger version
ID:	45703   Click image for larger version
  #1783 (permalink)
Old 05-14-2010, 09:46 PM
Fresh out of No Limit
just rolled out next to my Avalanche ready to head home
Name:	Chassis Front1.jpg
ID:	45658   Click image for larger version
Name:	Chassis Rear1.jpg
ID:	45659   Click image for larger version
Name:	Chassis next to AV1.jpg
  #1784 (permalink)
Old 05-14-2010, 10:02 PM
out of order
Chassis ready to go to No Limit
Name:	Chassis on Trailer1.jpg
  #1785 (permalink)
Old 05-15-2010, 01:58 PM
57halfton's Avatar
G&R
WOW you sure jumped into this project with both feet !!!!! How was your experience with NoLimit ? That was quite a trip down there and back , I hope they treated you well. I have done business with them several times, seem like good people. I have their Fat Bar suspension in my 57 halfton with air bags, but I didn't go with the compressor, air tank and switches. I just put air in to get the ride height I want and thats where it stays. I don't normally carry anything in the bed in my pickup.
Who's Rita? Your wife or one of the trucks? When my daughter drove my pickup alot she called it "Steven" she also named several other cars and the names seemed to stick.
Keep us posted on your progress and keep the pics coming. I still have to figure out how to post pictures on here myself.
Gene
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 09:24 AM
Mustang 2 Front end on a 55 Chevy truck? Slickriffs Suspension - Brakes - Steering 14 11-10-2010 06:10 PM
55 chevy truck rear end swap Wildman Transmission - Rearend 8 06-11-2007 07:16 PM
47-54 Chevy truck owners need a quick simple measurement sevt_chevelle Body - Exterior 2 06-18-2006 10:32 AM
nova subframe on a 59 chevy truck bet on black Suspension - Brakes - Steering 3 01-27-2005 08:48 PM
