yea, we are going to add support onto the front where we cut off, but im not sure what yet. We took off the original steering column mount to be able to mount our new one, so we still need to support that and the pedal, but we are going to come up with something.. When we do it, ill be sure to post pics. I used to design websites, so im working on one now to add all the photos so people can see it
Well i'm laid off again probably for all winter unless we have a dry winter here. I guess it's time to uncover my backyard pickup cab project and start where I left off last April, finish filling and smoothing my firewall holes
lookin good
58 apache
Richard my name is Johnny and I just recently started my 58 apache fleetside longbed 3200. I am looking for a good rearend that will swap out easily. The stock rear end isnt much. Im wanting something with a little more performance. I would love to hear some of the things you have customized on your pickup...swaybar...especially if the trucks rides as rough as you make it sound, beautiful truck by the way. Hope to hear from you..
Thanks -Johnny |
I put a rear end out of a '79 Trans Am under my '59 3100, it matched the 5 on 4-3/4" disc brake hubs I put up front. You will probably need an offset wheel or spacers to move the track width out to center in your fenders. I added 1" spacers and used longer wheel studs in my axles.
you want easy? as in no weld, then nothing will go in there. i have an 89 trans am 3.27 posi w/ disk. i cut off everything and welded on new spring pads you want performance? you already have a 4.11 under your truck for better highway speeds go to 3.27/3.08 or lower you want to see mods? read all 2000+ posts in this thread there is a lot of good info in this thread all of these are 5x4-3/4 and will not match a stock 6 lug front axles |
Johnny I have A GM 10 bolt out of a 87 GMC pick up.The existing leaf pads get cut off and 2 inch wide leaf pads get welded on(I got mine from summit).The advantage to that is you keep the 6 bolt pattern and can run stock rims.If you look through the posts you will find pictures and explinations on the changes I made to my 58 Chevy 3200
After searching the web I found a Vintage Air heater and defroster unit for 220.00 bucks from Summit , nice little unit. I'll let everyone know how it works after I install it, probably after thing get back to normal after Christmas.
| Recent Hotrodders' Lounge posts with photos |
| 1953 Chevy Truck Vin Help | Homeseller | Hotrodding Basics | 14 | 08-12-2012 09:24 AM |
| Mustang 2 Front end on a 55 Chevy truck? | Slickriffs | Suspension - Brakes - Steering | 14 | 11-10-2010 06:10 PM |
| 55 chevy truck rear end swap | Wildman | Transmission - Rearend | 8 | 06-11-2007 07:16 PM |
| 47-54 Chevy truck owners need a quick simple measurement | sevt_chevelle | Body - Exterior | 2 | 06-18-2006 10:32 AM |
| nova subframe on a 59 chevy truck | bet on black | Suspension - Brakes - Steering | 3 | 01-27-2005 08:48 PM |
