Hotrodders Bulletin Board
#196
thank you all so much.... i have everything off of the truck except for the cab so i dont think i will have a problem clearing the truck. i hope it goes well..... no broken toes for me please!
#197
I wondered the same thing when I took mine out. I'm going to put it back in the same way. If I had a lift to get the truck up in the air I would opt to put them in seperately but I'm going to try and put them in together. I think coming out together was easier than putting them in together is going to be. I still have the front end on my truck. I took out the radiator but the grill etc was too much to mess with. Just had to get it all up in the air high enough to clear. If you have the front off the truck it shouldn't be any problem at all.
Dave |
#198
dropped axle
#199
This truck I'm working on is going to be for weekend fun, rod runs around town and just fun. I've had it up to 80 with no problem and really don't see the need in going any faster. I like to build a truck with a basic theme in mind for the truck. This one is a tubbed out old school feel with a bottle rocket engine and gears. I agree with the sub frame idea. I wanted to lower this truck without going that route and keep the straight axle. I actually like the original steering in this particular truck. Going to put the works on the 53 I drive everyday. The rear is where I want it already and rides pretty well for what it is. I may take out a leaf or two on the front end. Thanks for the input.
Dave |
#200
Bone stock these old trucks drive like a bowl of soup.The combination of front and rear sway bars with the traction bars ties it all together and eliminates the buck board bounce and sway.The control arm suspension provides a smoother ride but my strait axle suspension 58 handles better than my 97 astro van .I ordered a hellwig rear sway bar for the van because I drive the 58 all the time so I really notice how sloppy the suspension on the van is when I am forced to drive it on road trips to Vegas.In my opinion the strait axle is not a hazard if it is not worn out and sloppy at the shackles.The hazard is the old style tie rod ends that can come apart while driving.A 6000lb truck will never handle like a car no mater what suspension you put under it.Controlling how that weight is transfered around on the suspension is the most important thing when it comes to handling.
#201
I guess that is part of the point I was making. One of the things that attracts me to these old trucks is that they are old trucks. I do like trucks with altered suspensions too, but my first love is the old straight axle. My 53 has the stock front and rear suspension and I drive it everyday. I have had it on the interstate a few times also. It drives like an old truck. Then I get in my 64 Impala 4 door hardtop with the power glide 327 and I float down the road like a big boat on a smooth lake. Variety is the spice of life. If I actually had to choose one over the other it would have to be my old trucks.
Dave |
#202
Strait axles worked on gassers for years and you don't see T buckets with independent front suspension.Tom Meyer's truck is nice with its camaro suspension and I love the 4 link on Kim's truck but that isn't what I want for my work truck. I have to go off road to a job site once in a while.I like knowing I have 14 inches of ground clearance on my headers and when I pull my trailer it doesn't push my truck around at all.
#204
#208
If we all liked the same thing we'd surely run out of em.
Dave Sorry but I'm no help on the casting numbers |
#209
Streamline55 you might find something here to help with your trans code.
http://chevy.tocmp.com/chevyresources.htm Good luck. Kim |
#210
DD.... did you have any trouble with the power booster conflicting with the transmission mount? There is no way this power unit is going in the stock location without doing something with this mount. Looks like I'll need to cut a larger access hole in the floor to get to the master cylinder resevoir. I'm going to give CPP a call in the morning. I bet I have to use a different trans mount to make this bolt in install work. Got all my wiring out tonight and gutting the interior. Got the old MC out and also took out the clutch pedal. It had been left in the truck under the mat.
Dave |
Back to top |
| Currently Active Users Viewing This Thread: 3 (1 members and 2 guests) | |
| 57halfton |
Similar Threads for: "55 to 59 chevy truck owners"
| 1953 Chevy Truck Vin Help | Homeseller | Hotrodding Basics | 13 | 07-12-2009 09:43 PM |
| 55 chevy truck rear end swap | Wildman | Transmission - Rearend | 8 | 06-11-2007 07:16 PM |
| 47-54 Chevy truck owners need a quick simple measurement | sevt_chevelle | Body - Exterior | 2 | 06-18-2006 10:32 AM |
| Mustang 2 Front end on a 55 Chevy truck? | Slickriffs | Suspension - Brakes - Steering | 2 | 05-16-2006 08:58 AM |
| nova subframe on a 59 chevy truck | bet on black | Suspension - Brakes - Steering | 3 | 01-27-2005 08:48 PM |
