I AM,PM me with the details...
Cole |
My chevy engine type??
thought i had a 327 per the previous owner, but after more reading, i may have a 350...
Here's what i have on the block: 11B110539 K08 28 CJD from what i gathered, it was made in Canada on Aug 28. The CJD appears to be a 350 from 1971. Any help would be appreciated. Once i get the engine ID, i want to replace the carb (current is a 2jet rochester with manual choke) in conjunction with the fuel tank and lines. im still having engine starting problems, it wont turn over. after checking the distributor, i am getting sparks. but no current going through the plug wires. is it the ignition coil. suggestions? |
sparks????? Do you mean it has points???? Have you ever had it running???
thanks for replying, excuse my lack of knowledge/ description on this subject. it is using points. when we hit the starter with the disributor cap off, it would rotate and the current was visable (saw sparks). my buddy took a plug wire off the plug and we tested to see if there was any current getting to the plug. there wasn't.
i had it running a couple of months ago, but even then it was touch and go when i could turn the engine over. |
I don't recognize the engine # posted did you get that from the block where the trans bolts up on the pad by the distributor ?
Cole |
i got it off the front of the block on the passenger side
Cole |
Torque specs for rear end
I am building a 1957 Chevy truck rear end. I would like to know if anybody here has the torque specs for the ring gear bolts and the rotational torque specs for the preload on the pinion gear and the ring gear carrier. Any help would be appreciated. Thanks.
the big cap electronic distributors will not fit in our trucks without modification
but i highly recomend the pertronixs points replacements my son has run the same set in his 68 elco for 8 yrs |
I Was thinking about the possibility of putting an HEI distributor in there too...
Is that not a good option? |
So you guy's please give me your input on this how much do you think it is worth, The guy told me it was a confiscation for money owed for storage and he will let me have it right but it has to sit a little longer to get a title from the state. But he told me he knows it's his truck the guy will not pay him. So i will just have to wait and see for sure though. This stuff can go either way. I don't know what engine is in it all i know is it has a chevy firing order. Cole |
| Recent Hotrodders' Lounge posts with photos |
| 1953 Chevy Truck Vin Help | Homeseller | Hotrodding Basics | 14 | 08-12-2012 09:24 AM |
| Mustang 2 Front end on a 55 Chevy truck? | Slickriffs | Suspension - Brakes - Steering | 14 | 11-10-2010 06:10 PM |
| 55 chevy truck rear end swap | Wildman | Transmission - Rearend | 8 | 06-11-2007 07:16 PM |
| 47-54 Chevy truck owners need a quick simple measurement | sevt_chevelle | Body - Exterior | 2 | 06-18-2006 10:32 AM |
| nova subframe on a 59 chevy truck | bet on black | Suspension - Brakes - Steering | 3 | 01-27-2005 08:48 PM |
