55 to 59 chevy truck owners - Page 168 - Hot Rod Forum : Hotrodders Bulletin Board
  #2506 (permalink)
Old 07-27-2011, 09:58 AM
ogre's Avatar
the 'Duracell Project'
anyone try these latches? altman easy latch
a little pricey at $350 for the set
  #2507 (permalink)
Old 07-27-2011, 01:20 PM
I've got them, now all I have to do is align the doors and install them.
  #2508 (permalink)
Old 07-29-2011, 09:37 PM
banjodr's Avatar
Fianally!
Well I got the '59 Apache up on the lift today to see what was up with a puddle of transmission fluid underneath and found 3 leaks but all on the outside. It doesn't look like I'll have to open it up. What is the consensus on switching out the original drum brake assembly for an outfit that will stop the truck and smooth out the ride a bit? I think I'm ready to light the candle. Also anybody got a radiator suggestion? I have a small leak in the original one also. thanks
  #2509 (permalink)
Old 07-30-2011, 07:41 AM
Originally Posted by ogre
58apache
i've seen a few but they didn't look right.
mine is the original chrome, but i've seen body color grills that looks really nice.
my chrome turn bezels were pitted. i sand blasted them and used body color on them
put some color on it and see if you like it.
It looks different for sure! There's an aspect of it i like! I think I am going with a different body color, likely Black, so trying to imagine what it would look like and I am thinking good! Nice idea! Thanks!
  #2510 (permalink)
Old 07-30-2011, 09:54 AM
ogre's Avatar
do it this weekend and write up a review
  #2511 (permalink)
Old 07-30-2011, 02:28 PM
DOUBLEDICK's Avatar
I have one from Brothers Trucks in my 58.It is a modern 3 core radiator in stock brackets and you can get a shroud for it too.I run a 427 big block and have had no overheat issues even when I go to Las Vegas in the summertime.
  #2512 (permalink)
Old 07-30-2011, 02:48 PM
banjodr's Avatar
Great thanks, I'll check it out
  #2513 (permalink)
Old 07-30-2011, 04:30 PM
ogre's Avatar
i have the same one, with the trans cooler if your running an automatic
  #2514 (permalink)
Old 07-30-2011, 10:14 PM
This weekend I'm in Arroyo Grande,CA for the car show
When I get home the wife has a honey do list waiting for me
Not to worry I've got my own list of projects for the '57 but the '56 is on the lift now and wants service and brakes.
ID:	57218   Click image for larger version
  #2515 (permalink)
Old 08-04-2011, 02:32 PM
LDO LDO is offline
Upper Radiator Support Panel
Does anyone know where I can find the rad support panel? I hope I'm calling it the correct name. I have a 57 Truck and I have the normal panel that houses the hood latch. What I'm looking for is the panel that bolts to that and to the rad support bar.
  #2516 (permalink)
Old 08-04-2011, 06:27 PM
banjodr's Avatar
Converting from my drum brakes to disk
What are the best realistic options for converting my 59 Apache's original drum brakes to a good disk brake system and also coil spring suspension? I've already settled in on adding rack an pinion steering so is there a package somewhere that does it all at a reasonable price? thanks for your help
  #2517 (permalink)
Old 08-04-2011, 08:07 PM
Check out LMC Truck http://www.lmctruck.com They have the upper grill bar, the latch panel and the Rad support panel and just about anything else you need.
  #2518 (permalink)
Old 08-04-2011, 08:09 PM
LMC Truck has what your looking for.
  #2519 (permalink)
Old 08-04-2011, 08:59 PM
  #2520 (permalink)
Old 08-05-2011, 05:47 AM
LDO LDO is offline
Thanks but I checked LMC, Classic Parts, Ecklers and a few others. I'm beginning to think this part isn't sold by anyone.
Here's what I'm after and how it bolts on. Hope I'm calling it by the correct name.
Name:	upper rad panel.jpg
ID:	57349   Click image for larger version
Name:	upper rad panel 2.jpg
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 09:24 AM
Mustang 2 Front end on a 55 Chevy truck? Slickriffs Suspension - Brakes - Steering 14 11-10-2010 06:10 PM
55 chevy truck rear end swap Wildman Transmission - Rearend 8 06-11-2007 07:16 PM
47-54 Chevy truck owners need a quick simple measurement sevt_chevelle Body - Exterior 2 06-18-2006 10:32 AM
nova subframe on a 59 chevy truck bet on black Suspension - Brakes - Steering 3 01-27-2005 08:48 PM
