Hotrodders Bulletin Board
#286
I'll get a pic of it and post it. The space behind the rear axle is limited due to the coil overs and the way the truck was tubbed. It is mechanically sound but not the cleanest or best way to get the job done. I may have plenty of room but just looking at it I may be limited. I'd just have to get some dimensions on the bronco tank. I do know I'd like to get the gas tank out of the cab.
Dave |
#287
apparently the tanks are 23 gallon (just looked it up) and the dimentions are 24" x 29" x 15". remember you have to either move the rear crossmember back, or notch out the bottom for the tank to fit.
#288
gas tank
dave - i will see if i can find the thread - it was either this site or the jalopy journal / HAMB site that someone used a tank that mounted inside the frame just behind the cab, like the later model chevy trucks. there was one tank that fit really well - oh yeah - it is willys36's project journal on this site. early in his journal he created an extended cab truck - check out his journal and see if that helps as far as a gas tank idea.
#289
Lowered Trucks
Wow !!!! This quite a thread you guys have going here.
I have a question for everyone who has lowered their pickups. In the rear of my 57 which has also been lowered with mono leaf springs , I have about 2 inches of tire showing between the top of the rim and the edge of the fender opening. I have not notched the frame yet for more axle/ suspension travel and I have about 2 inches of clearance between the axle tubes and the stock rubber stops under the frame. On bumps and when i've put some weight in the back it does hit the stops , SO to fix that i'll box and notch the frame, more clearance, more travel, smoother ride. BUT , I have noticed that the center section of my 10 bolt Chevelle rearend has been hitting the underside of the wood floor of the bed. To you all that have notched frames and have gone even lower what did ya do about the rearend hitting the underside of your bed floor ???????? Thanks ,Gene |
#290
I've heard that a 69 or 70 mustang gas tank fits under the bed of our trucks.
Gene |
#291
I Have a 70 Mustang Fabed into my '57 Truck
I built a 1 " tubing frame around with two front and two rear brackets that go up to the frame to mount a 70 Mustang tank . I had to move the back cross member to the rear of the frame. It is my site www.meyerbrosrods.com under Tom's 57 Truck.
#292
hey 57halfton, i think that there is not a way around the rear end hitting the bed. im going to put air ride on my truck so either i have holes in my bed floor or i raise the floor so i still looks some what stock.
#293
http://www.hotrodders.com/forum/jou...age=5&reverse=1 Here is the link to Willy's gas tank install. I might look at doing it this way also. I saw at a truck show someone had used a ranger tank in the same place Willy mounted his. |
#294
Gator there is only 12 inches of clearance between the frame and the drive shaft.A tank like the one on the willy wont fit.I was going to use one off a 92 1500 and mount it that way on the passenger side but there just isn't room.With this fleet side bed the only thing that looks like it will work for me is the saddle bag tanks off a mid 80's Chevy truck.I haven't run a tape across a set yet but I will when I can get out to the wrecking yard.They are snowed in right now so that will have to wait.You don't have that option with a step side bed.My 59 was a long bed step side but I like the extra bed space in this fleet side bed.I thought it was ugly when I bought it but I wouldn't go back to a step side now.The bed cover really changed the looks of the bed and I need the extra room for my tools and supplies when I am working.
#295
Yeah , I think i'm going to figure out how to raise the floor of mine an inch or so. I'm looking at that Fat Bar 4 link setup from NoLimit eng. with air bags for my truck , then raise the floor. Only want to take the bed off once for now, then again for paint (someday) Gene |
#296
DD- thats not helping me.... I like you want to put a hitch on the back of my truck. I will soon have the cab off and will be able to measure things a little better. Let me know if you find something and I will do the same |
#297
I have an '83 Chevy C-30 with the side-saddle tanks out in my driveway as we speak. Let me know what measurements you need, and I'll do my best. The bed is still on it, so everything will have to be measured from beneath the truck - hope that doesn't cause a problem. If you want pictures, I can do that too. I'm about 30 miles east of Carson City. No snow here, but it's still colder than a well digger's belt buckle. It's times like this that I wonder why I ever left Hawaii... |
#298
Dusty82 you are still 500 miles from me which will not make it cost effective to come get them but thanks for the offer.Gator I know you dont want to here this but if you come to Ely you can get that short bed frame and fleetside box at this wrecking yard.I bet he would take $500 for the whole truck.The cab is junk and stripped but its a good parts piece.
#299
DD thanks for the offer for the short bed find. But I like the stepside look more than the fleetside. But hey I might change my mind.
Hey Dusty82 what are the measurements for the saddle tanks? I would like to see if that model would fit on my 55 truck. Thanks, James |
#300
Hey guys, i have herd about using a 78-87 monte carlo clip instead of a camaro clip, i know where i can get a 78 cutlass supreme for next to nothing. i need some help from some one who has used a monte clip. and if im not mistaken a 78 supreme is the same as a monte right? i need to get my suspension done within the next 2 months. please help!!!
Back to top |
Similar Threads for: "55 to 59 chevy truck owners"
| 1953 Chevy Truck Vin Help | Homeseller | Hotrodding Basics | 13 | 07-12-2009 09:43 PM |
| 55 chevy truck rear end swap | Wildman | Transmission - Rearend | 8 | 06-11-2007 07:16 PM |
| 47-54 Chevy truck owners need a quick simple measurement | sevt_chevelle | Body - Exterior | 2 | 06-18-2006 10:32 AM |
| Mustang 2 Front end on a 55 Chevy truck? | Slickriffs | Suspension - Brakes - Steering | 2 | 05-16-2006 08:58 AM |
| nova subframe on a 59 chevy truck | bet on black | Suspension - Brakes - Steering | 3 | 01-27-2005 08:48 PM |
