Hotrodders Bulletin Board
#736
Thanks for the compliment James! Hope you get a good buy with the intake/carb. As soon as school is over in a couple days, I think I'll start redoing some of the body. It's been a year since my first attempt at bodywork. Some of it I'm proud of, but there are several small places you can see up close that need some more work. Back then I had no idea of the proper way to hammer dents out. I think I'm going to buy a new oil pan, the cheap chrome one on there now seems to be leaking a little at the back. While reinstalling the engine after the rebuild, as we put the engine in the bed of a different truck, I was stupid and let the engine hoist down a little too fast while we took it out. It wasn't much, but the pan got just a little distorted, and I'm thinking that might be causing this leak. Oil needs changed anyway.
Trans guy picked up the Muncie today, decided to take it with him. They shortened the hours at his shop, so he's glad to redo it for us and make some extra cash. He said it will only take a couple days. If I can find them, I'll also post a couple old in-progress pics as I was first sanding the truck down, and one or two of some (novice) pinstriping I've done. Sorry this post is so long! -Matt |
#737
pics of dads cameo
Here are some pics of the truck I will have to go take a shifter picture tommorow. I will look at the tranny and get info also to tell if it is original or not too. The shifter is so low you can't see it in these interior shots. Thanks for all your help. John
#739
Gator If your interested at www.classicsandrods.com in the forums in the garage sale section is a edelbrock TM-1 manifold.That is the same intake I run(TM-2) on my truck except it is for a small block. |
#740
Thanks DD...I bought the intake and carb for $80 last night. I had a 2bbl on it and want a 4 bbl. Seems the guy I bought it from wants to look at my 2bbl...he wants to run triple twos!...way cool!
Later |
#741
try Lokar, they have alot of different shifters at different heights with different curves for many applications. |
#742
Hey everybody-I'm Keith Lebo from Fairfield CT-My truck is a 55 second series-3/4 ton.
I have a post in the suspension area and Double Dick tipped me off to this thread. Great read! This summer I'll have my cab and frame stripped and it's time to think about the suspension, steering, brakes. I plan to use the Toyota setup for steering. I had been thinking I was going to put in a 3" dropped axel. I've read 40 pages of this thread and will pick up again at work tomorrow. What I'm really after is the results of the mono leaf front spring or the dropped axel. Of those of you that have excuted this mod what were the results? Looking at my truck tonight I noticed an obstacle relative to the dropped axel. If the axel is dropped any amount the leaf springs will be resting on the tie rod. Won't clear going over the top of the springs I don't believe. Lowering the front end on this model truck using a dropped axel must have been done many many times. Anyone know how this gets resolved? Seems like the tie rod would have to have a 3" drop also. Alternatives? Thanks, Keith Last edited by Slickriffs : 05-24-2007 at 07:43 PM. |
#743
Hey Keith
Later, James |
#744
Hey guys, just an update...the Muncie is done! He gave us the bad parts that were in the trans before, said the problems were obvious on the parts but I don't know enough about these things to tell much. He also said he was surprised it held together like it did, if I would have gotten on it much I would have broke the case. Now it's good, and he stands by his work. If I work fast, I think I can put it back in the truck tonight.
-Matt |
#745
Matt glad you got your tranny back. Its encouraging to see a young kid like you take an interest in the classic iron.
Kim |
#746
Slickriffs I can,t find any information on drop axles anywhere.I cant even find anyone that sells them.It looks to me like if there is such a thing as a drop axle for these trucks it would bolt in on top of the springs instead of under the springs.It would need to use modern tie rod ends and they would go in from the top instead of the bottom like the stock style tie rod ends.That would allow the tie rod to go over the spring instead of under it. This is only my best guess as I have never seen one. Matt I am glad you got your transmission fixed and back in your truck.Keep on driving that truck
#747
4 speed tranny on 56 cameo
I looked at the 4 speed tranny last night but forgot my camera. I could not find any #s on it. Will I have to remove the cover above the tranny to find #s or would they be visible from below. Does anyone know where they would be located? A general area maybe. Thanks for any info on this.
#748
Hey guys..
I have a 59' apache, 1 ton flatbed that I'm fixing up. I put bucket seats in yesterday (along with a new stereo and ignition switch) Now, the old bench seat that was in there. Dad says it's the original seat frame and springs, just newly upholstered. It's all in good condition. One problem, I have NO idea how much to ask for it in the local papers!
I looked in the classifieds (first off to see if I should post this question in there) also to see if there were more so I could base the price on them. Any advice? (If this is the wrong section, just point me in the right one and I'll delete this one and repost there) L8er, Crystal |
#749
ApacheAngel I just rebuilt the frame work and had my 58 seat reupholstered.It cost me 400$.You should be able to get $200 out of your seat.The problem is finding someone that needs one as most people put in bucket seats like you did
#750
I got started on my windows fore the 58 yesterday.I had the usual rusted bolts that needed a chisel on the edge to get them lose but no real problems taking the glass out.The real problem so far has been relining the center post with the felt.The chrome bead is what holds the edges of the felt.It is impossible to take off and reinstall them without damaging them.LMC has this middle post already relined.If I had it to do again I would buy them already relined.Here are a couple pictures
Back to top |
Similar Threads for: "55 to 59 chevy truck owners"
| 1953 Chevy Truck Vin Help | Homeseller | Hotrodding Basics | 13 | 07-12-2009 09:43 PM |
| 55 chevy truck rear end swap | Wildman | Transmission - Rearend | 8 | 06-11-2007 07:16 PM |
| 47-54 Chevy truck owners need a quick simple measurement | sevt_chevelle | Body - Exterior | 2 | 06-18-2006 10:32 AM |
| Mustang 2 Front end on a 55 Chevy truck? | Slickriffs | Suspension - Brakes - Steering | 2 | 05-16-2006 08:58 AM |
| nova subframe on a 59 chevy truck | bet on black | Suspension - Brakes - Steering | 3 | 01-27-2005 08:48 PM |
