Hotrodders Bulletin Board
#991
Best bet is to call Mar K and ask them. Antny |
#992
Hi this is my first time
Hi everyone. I am building a 57chev step-side pro-street. I am new to this. My problem is i don't know what rear end to use. I have an '86 chev pk up rearend, a 8.8 Lincoln rearend with disc brakes. Can these be narrowed down easily? And I have been thinking about an s-10 rear end because it is narrower then the stock one already but i don't know if it will stand up to 400+ hp. Does anyone have any suggestion which would be the best way to go?
#993
re: 55 to 59 Chevy truck owners
I have a 59 Chevy Fleetside under construction (for 8 years) and I was going to paint my frame with oil based Rust-oleum high performance paint and primer. Has any one done this before and what was the results. This is going to be driven quite often, I don't have the extra money to use epoxy paint. I can spray it according to the instructions, using acetone as a thinner. Has anyone done this before on their vehicle? How well did it hold up under normal use? Can I use a universal hardener in it or is this a bad ideal to start with. Any thoughts on this would be helpful. Thanks.
#994
56 IFS Measurements
I started to install a M11 IFS on my 56 truck frame today - my issue is the distance from the front end. I measured my old axle centerline at 28in from the front ( or 22 in from the center of the front spring mount hole ). The instructions state the crossmember centerline should be 20 7/8 in from spring hole center (27 in on my truck ). Anyone recall the measurements they used? I'd hate to weld it up an inch off !!!! Thanks.
#995
Bignuk1, I think mine was 20-7/8 inches. But also do this; mark the centerline of your rear axle on the floor on each sibe of the truck using a plumb bob or level, then measure the proper wheelbase (I think it's 114 inches for the shortbox, 117.5 for the longbed?) and mark it on the floor. Transfer the wheelbase mark up to the centerline of your crossmember, again with a plumb bob or level. Do that on both sides and tack her in. Recheck all your measurements and marks a few times before final welding. This method with guarantee that your front wheels will be properly centered in your fenders. Hope this helps. Antny |
#996
Cool 59, If I was looking for frame paint for a daily driver I would use POR 15. It brushes on and flows out smooth. I painted a chevelle frame and it looked great. UV will harm it but on a frame it should be no problem. Kim |
#997
#998
Depends on the definition of "too bad" is....! All that's missing is a sink and a potty! |
#999
Hey guys
Hey everybody...been awhile since I've been here. Life has been crazy, but hopefully things are slowing down now. My truck is pretty much the same as last time I posted. So maybe I can get back on it. Nice to be back..
#1000
I used black rustoleum from the can and brushed it on. I am not building a show truck just a daily driver. I pushed the rolling chassis out into the weather about 4 months ago and it has held up well. It is just a bit dusty and dirty but holding up |
#1001
re, rust-oleum
Thanks for the the reply about rust-oleum. I have a good amount of money in my truck. I put the money in things that I thought was necessary for making it safe, more modern, handle better and durability. I'm at the point where I need to get it done and quit trying to re-engineer it. The sky is the limit on how much money you can put into a rebuild. A lot of rebuilds have much more money in their trucks and they do impress me with their skill they have in building their vehicles. My funds are kind of funny right now, so I'm trying to do the best I can do with what I have to work with. My goal is to get it done as soon as possible. Thanks again.
#1002
58-59 chevy
Hey, anyone out there near Dayton, Ohio building a 55 to 59 chevy truck? Just interested in your project and how its going. It has been cold here for awhile and I'm losing my motivation to get out in the garage an accomplish anything.
#1003
Me too I am in So. Maryland My barn need a roof its been cold I have tons I could be doing but instead I am in the gym, Lots of work needed there too and soon its better riding conditions so I will have a v-twin distraction ,, I need serious help, Oh yeah in April I will have to go fishing as well!,, come on global warming!
#1004
re, 58-59 chevy
I have lost track of how long I have been on this project. I found old receipts dating back to 2001. I don't have extra money to put in it right now, so right now I am trying to do the labor intensive part of the project with the least amount of money possible. I have set a goal to get it done this year and to drive it. Now with cold weather all I need is motivation.
#1005
I think there is alot of things in this truck that should have been taking out at the house and left there, |
Back to top |
Similar Threads for: "55 to 59 chevy truck owners"
| 1953 Chevy Truck Vin Help | Homeseller | Hotrodding Basics | 13 | 07-12-2009 09:43 PM |
| 55 chevy truck rear end swap | Wildman | Transmission - Rearend | 8 | 06-11-2007 07:16 PM |
| 47-54 Chevy truck owners need a quick simple measurement | sevt_chevelle | Body - Exterior | 2 | 06-18-2006 10:32 AM |
| Mustang 2 Front end on a 55 Chevy truck? | Slickriffs | Suspension - Brakes - Steering | 2 | 05-16-2006 08:58 AM |
| nova subframe on a 59 chevy truck | bet on black | Suspension - Brakes - Steering | 3 | 01-27-2005 08:48 PM |
