DD thanks for the help, you to Nolan! So let me get this right. I will set my engine at 0 degrees off the intake manifold. (I will actually rest the angle finder on the carb...any problems with that?) To place the engine front to back I will "mount" it with the front motor mounts, mark the new engine cross member on the frame, then move the new engine cross member 1" forward to allow for bigger distributer later. After I drill and bolt the new engine cross member to the frame I'll double check the engine angle and place the new transmission crossmember (bolted to the tranny.) I will shim as required to make sure the engine sits at 0 degrees then I will drill the frame for the new tranny crossmember. Once this is done and both crossmembers are in and the engine sits level I will weld the engine crossmember together where the crossmember tube slides into the frame mounting brackets that are bolted to the frame.
Ok does this sound right....let me know guys. Thanks again. |
Yea sounds like that is the way I will do it. I have the same booster as you. How did you raise the engine 2". I know I can bolt the crossmember high, but I am not sure I could get 2".
I need to see about some headers also for my sbc 350. I would like to have full length headers. |
Gator I just raised the engine crossmember as high in the frame as it would go.The reason I ended up with 2 inches has to do with the trans not the engine.I bolted a 700R4 to a 350 crossmember.That spacer is 2 inch thick wall square tubing.one side is drilled to match the trans with large holes drilled opposite them for access with a socket.The other side is drilled to match the crossmember.I just dropped those bolts through the holes and used grade 8 bolts with self locking nuts.Yours will be a little different and I don't remember what trans you plan to run.I will have to do mine all over again now that I am upgrading to a 4L80E which is a much bigger transmission so I will have to move the cross members again.I recommend you drill and bolt the feet to your crossmember instead of welding it because you wont be able to remove the crossmember ever again without cutting it in half(remember taking out the stock crossmember).Always leave yourself options.I never dreamed I would be on my 3rd different(T5,700R4,4l80E)transmission in 5 years. You never know when that camaro with all the parts you want is going to be for sale.Just ask Roadkill58.When I picked up my brand new never installed in anything 4L80E with 1800 stall 6 pad torque converter from expert transmission for $2000 I wasn't activly looking for one.I was just there to have my custom 700R4 rebuilt
I still have a 871 blower and fuel injection on my mind you just never know
I still have a 871 blower and fuel injection on my mind you just never know. DD, Injection would be a good thing for your truck. It would eliminate your mountainous tuning issues. It would depending on the type of fuel injection you add. Being blown is always a good thing. |
Hey Jmigatr --duh !
DUH OH O, I didn't think about the carb base not being parallel to the crank. This is not a valid place to measure from. You better follow DoubleD's instructions, he knows. Question for DD, DD where did your pinion angle fall at when you replaced your rearend? I went out and rechecked mine after I read your post. My LT1 intake is parallel to the crank so my down angle is ok. But my rear is the same angle (about 3 degrees up) so I'm either gonna have to shim the rear a bit to account for spring wrap up or go with the solid traction bar to prevent it. I'm also thinkin I might be better off replacing the springs first(I'm going lower in front) because everything is gonna change. What is your opinion on my setup? I know you have smoked the tires off of yours, broke stuff, then got it to hook good. I believe I'd like to duplicate your setup as it sits. Nolan
I have this weekend ready to install the engine and tranny...so hopefully I can start later today, by sneaking away from work early.....but wait there is a big car show here Saturday...might have to go. |
I spent the weekend in the mountains and am all rested up.OLNOLAN as long as your angle on the rear end is the same or close to the trans angle you will be fine.The spring wrap is only an issue if it ends in wheel hop.Because a u joint has an elliptical path if the angles are not exact opposites you will have a slight harmonic vibration when cruising.4x4 trucks that have been lifted usually do not have the same angle off the rear as the trans does and as long as the u joint does not bind it will work fine.When I installed my rearend I had never done one before and I had no angle gauge so I just pointed the pinion at the transmission.My rearend actually is up too high so I am 2 degrees the other way on my drive shaft angle .The only issue I have is a harmonic vibration at high speeds(70 or above).This proves that even with allot of spring wrap you wont have any real problems with your pinion angle.I have done several burn out contests and runs down the strip without any u joint problems.I will correct the angle when I change drive trains.If your go with a set of traction bars like mine you will need to make some heavy duty mounts as the ones that come with the kit(I got mine from Brothers Trucks) cant handle big horse power.I included pictures of the ones I made feel free to copy them.I made one from cardboard first.It took several tries to come up with a design I liked.They are drag strip tested
DD: Thanks for the info.
I will check out that article. Did you buy that trans controller? "Edelbrock Pro-Flo XT" http://www.edelbrock.com/automotive_...xt_intro.shtml Simmit has them for small block http://store.summitracing.com/egnsea...p?N=115+328385 Check out my project journal. Last edited by Roadkill58; 05-26-2009 at 11:49 PM. Reason: add url |
Hey Doubledick
Glad you got good rest in mountains. How about posting a photo of the mountain views? I have been to Vegas for Nascar race, saw a few mountains,far west as I've been, we flew in for the race didn't have time to see much. I appreciate your feedback on driveline stuff. I didn't have any issues with the 350/stick shift before swapping in the LT1 and T56, actually didn't have wheel hop, but no traction on hole shots. I am being careful with setup cause stick shifts will break stuff. I'm eventually gonna do a posi unit like yours, right now I'm peg- leggin. I'm gonna need the traction bars then. I liked the re-engineered brackets on yours BUT at $280.00 from Brothers and having to remake the front mounts I think I'm gonna pass on those, maybe try a less expensive slapper bar or something. Man it's a drag when you gotta save up $ to get your hotrod together. Mine is movin slow. Put the blower on yours, I dare ya! I'm sitting on a 502, super duty block with all forged rotating assembly,
rectangle port heads and get this, it's only 8.5:1, what a blower motor it could be! I'm saving it for a special hotrod. If you are interested in how I bought it for a mere $1500, let me know. There's a way to get bulletproof big blocks like this cheap if you know what you're lookin for.Later,OLNOLAN |
Roadkill58 I did not get my controller yet.I have to get my shop up this summer.But I did do all the research and want the one from powertrainsolutions along with the paddle shifters.
Good news! They have the Pro-Flo XT for big blocks.
They have them for oval, and rectangular ports. I checked out Edelbrock's booth (more like big rig) at the Goodguys meet in Pleasanton today. Good turnout, autocross, swapmeet, tools. And lots of cool cars, and trucks. Good way to get motivated. Last edited by Roadkill58; 06-02-2009 at 06:16 PM. |
For standard deck and rectangular ports:
Pro-Flo XT as cast #3558 and Pro-Flo XT with black powder coated finnish #35583 Recommended intake gasket: #7202 They also have them for the LS1 engines as well. http://www.edelbrock.com/automotive_...xt_chevy.shtml The ones for big blocks is at the bottom of the page. |
| Recent Hotrodders' Lounge posts with photos |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| 1953 Chevy Truck Vin Help | Homeseller | Hotrodding Basics | 14 | 08-12-2012 09:24 AM |
| Mustang 2 Front end on a 55 Chevy truck? | Slickriffs | Suspension - Brakes - Steering | 14 | 11-10-2010 06:10 PM |
| 55 chevy truck rear end swap | Wildman | Transmission - Rearend | 8 | 06-11-2007 07:16 PM |
| 47-54 Chevy truck owners need a quick simple measurement | sevt_chevelle | Body - Exterior | 2 | 06-18-2006 10:32 AM |
| nova subframe on a 59 chevy truck | bet on black | Suspension - Brakes - Steering | 3 | 01-27-2005 08:48 PM |
