55 to 59 chevy truck owners - Page 99 - Hot Rod Forum : Hotrodders Bulletin Board
  #1471 (permalink)
Old 11-14-2009, 07:04 PM
Lil John's Avatar
Wanabe Mechanic
Last journal entry: 55 chevy 2nd series truck
The only pics I have are a few months old now. I was out wielding up holes in my floor I'm not using. I pushed the truck out of the garage to clean my garage out and it took me an hour to get it pushed back in. I had my wife putting blocks under the wheels every step of the way. She is 5 months pregnant so I didn't want her to push on it.
ID:	41977   Click image for larger version
  #1472 (permalink)
Old 11-14-2009, 07:12 PM
Lil John's Avatar
Wanabe Mechanic
I was wondering if anyone has assembled door guts and made a journal of this I am not looking forward to that feat. It has been a long time since I disassembled mine . Pictures are nice. Any info on this would be appreciated.
  #1473 (permalink)
Old 11-15-2009, 11:52 AM
DOUBLEDICK's Avatar
I didn't make it into a journal but I replaced the window regulators and all the rubber parts and installed the green glass from Brothers Trucks in my doors.The hard part was getting the glass for the wing window back in the frame right.I ended up using my hard white rubber mallet to pound it back in the frame.There is a tech article on Brothers trucks web site I found helpful.It is called 55 to 59 weather stripping installation.Let me know if that helps.These doors are easy to work on.
  #1474 (permalink)
Old 11-15-2009, 05:48 PM
Lil John's Avatar
Wanabe Mechanic
Thank you DD I thought I had seen an article somewhere a while back but forgot where maybe that was it. I will check it out. Thanks , John
  #1475 (permalink)
Old 11-19-2009, 04:18 PM
ogre's Avatar
the 'Duracell Project'
new member
hello people of this 55-59 truck thread. just found this site, registered and thought i'd introduce myself. i own a 58 apache, big window and short stepside. what started out 7 yrs ago as a mild custom restoration has snowballed into a full rodification build.
i've been reading many of the posts here and looking thru some of the photo albums. some realy nice trucks here and some realy nice survivors too. i like stock, mild and wild. i'll figure out how to post and get some build pics up.
mine became a driver 2 weeks ago, cab and frame are complete. bed is a work in progress, most of the fab was completed yrs ago and put out to pasture in favor of getting the cab & frame done. i got carried away with the interior after looking into building a console, found fiberglassforums.com and the rest is history.
that's it for now.
ogre out
  #1476 (permalink)
Old 11-19-2009, 05:29 PM
DOUBLEDICK's Avatar
ogre Glad you jumped in To post pictures they need to be resized.I use PIXresizer.You can down load it free.just google it.I am not real savvy with this stuff so I move pictures to my desk top before resizing them so I can find them to attach to my posts.when you reply to a post scroll down and click on manage attachments after you attach pictures submit your post and the pictures will be there.Looking froward to pictures Also always use spell check before posting.It will save allot of editing.At least it does for me
  #1477 (permalink)
Old 11-19-2009, 09:58 PM
ogre's Avatar
this is the duracell project. yes it's a lousy cell phone pic.
  #1478 (permalink)
Old 11-20-2009, 09:28 AM
NDtruck's Avatar
'58 Longbox Fleetside
Originally Posted by Apache_Boy
Is there a complete frame that will work on the 57-59 Apache SWB?
I was told the S10 ext cab short bed, and the 80's SWB wont work.
In another forum I frequent, it seems the S-10's are more popular for the Advance design series of Chev trucks(47 thru '55 1st half), less so with our task forces (55 2nd thru 59). I believe because the dimensions fit that particular body a little closer.
that being said, by all means go for it. Would be sweet to hear a success story on there.
Seems like though with the required work as far as getting all the mounts correct for box, cab, fenders; misc bracket headaches, and so on that it might be just as much to put a new clip in the front. no? Though not as popular as the misc Mustang II IFS kits, a volare clip (I believe) slips right into the frame rails, also have heard good things about using a 1st gen dakota front clip.
Still plenty of hassles there to obviously, but hey do what you are gonna do. it's your project. Enjoy it man!
  #1479 (permalink)
Old 11-20-2009, 02:49 PM
ogre's Avatar
apache boy
new guy here. i looked at doing a frame swap when i started my 58. the axles on 55-59 are 60" wide. the older trucks 56 wide as are the s-10 trucks, thus many AD trucks sit on s-10 frames.
i'm not sure what your after, but i found the best frame for my truck was the one that came from the factory. a modified stock frame works well and you don't have to fab cab mounts, core mounts, bed mounts or change the length. i boxed my frame front to rear, added a cross member for the trans and to reinforce the front cab mounts. the thing nice about the stock frame is all the sheetmetal bolted right up after 6 yrs of my project.
i did a minor c-notch in the rear. stock springs with the overloads removed, 86 trans am rearend w/ 3.26 gear and disc brakes. i flipped the new axle on top of the springs
i wanted power brakes, but also needed a clean firewall. i used an 03 mustang hydroboost mounted in the stock location and used a stock pedal swing arm
3 big ticket items i had to have were 1) gm crate motor, 2) 700r4 trans and 3) must II frontend. but you could use a volare clip and still not mess with the front of the frame.
  #1480 (permalink)
Old 11-20-2009, 06:35 PM
Steven
Ya got a really nice apache there. I looking for a complete new frame. I cant use my stock one
  #1481 (permalink)
Old 11-21-2009, 04:28 PM
ogre's Avatar
fender mounted spare
spent all day making an adapter to mount the spare on the fender. old rim was 6x5.5" new rim is 5x4.75". needed to move the spare out 1/2" at the same time. i have axcess to autocad so i layed out the dimensions in autocan, printed it out and bought a chunk of 1/2" plate to lay it out on.
i'll cut the old studs off and weld the plate to the bracket. new holes will be filled with 1/2" fine thread bolts to mount the tire on. big hole in the center is just to lighten the plate.
  #1482 (permalink)
Old 11-21-2009, 04:36 PM
ogre's Avatar
nothing is easy
this is the bed i'm working on. frame is shortened 8" and the bed is cut off flush with the back of the fenders. trunk lid is from a chrysler 5th ave, had to section the trunk lid and frame 8" down the center.
also added a fuel door in the drivers fender
i do all my own work: welding, fab, bodywork and assembly. the only thing i don't do is paint. i have my truck in my buddy's shop, he has a painter that i use. it's also handy because i can use his tech to help with the heavy stuff or to hold the fender while i put bolts in.
  #1483 (permalink)
Old 11-21-2009, 04:41 PM
Steven
DAMN thats bad ***. I wish i had the skillz or cash to do work like that.
  #1484 (permalink)
Old 11-21-2009, 04:49 PM
ogre's Avatar
shaved cowl vent
i shaved the cowl vent. this is the slots in between the wipers that allows water, leaves and pine needles under the dash. this is the main cause for rust in your hinge pockets, leaks under the dash, rust on the firewall, etc...
  #1485 (permalink)
Old 11-21-2009, 10:54 PM
New Member
WOW, I just found this site. I am in the process of building my dad's 1955 suburban. Has been in the family since 1958. Had been in storage in Montana for the past 14 years. Didn't remember it being in this bad of condition, but oh well it was the first thing I ever drove so it will be worth saving.
So far we pulled the body off the frame. Had to locate another frame because this one was bent. Have installed a TCI front clip and a 10 bolt rear end from a 72 Nova. The body is back on the frame so I can get the engine in place and fab up some motor mounts. Have a 5.3L engine from an 03 Tahoe with 40k miles and 4L60E trans to power it.
Some of my plans are to install the dash from a 55/56 Chevy car, plug all the holes in the firewall (my dad drilled a lot of holes), add the one piece door glass, add a trailer hitch and newer fuel tank. I would also like the install a tilt steering column, but keep the stock steering wheel. If anyone has done this I would appreciate their input.
Right now we are most of my funds will be spent getting race cars ready for next season, so my progress may slow down. Oh yea, and then there are the items on my wife's list that I need to complete too.
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 09:24 AM
Mustang 2 Front end on a 55 Chevy truck? Slickriffs Suspension - Brakes - Steering 14 11-10-2010 06:10 PM
55 chevy truck rear end swap Wildman Transmission - Rearend 8 06-11-2007 07:16 PM
47-54 Chevy truck owners need a quick simple measurement sevt_chevelle Body - Exterior 2 06-18-2006 10:32 AM
nova subframe on a 59 chevy truck bet on black Suspension - Brakes - Steering 3 01-27-2005 08:48 PM
