Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55-59 door and cab woes
Old 01-11-2013, 10:46 PM
Alaska Gasser Alaska Gasser is offline
Last journal entry: Update
At the moment. I'm not planning on pancaking it but this is an ever evolving project so you never know.
I just got done installing a '58 Chev p/u dash into it and am using a flamed aftermarket gauge cluster. To make it fit better, I cut and widened the hump over the speedo by almost 2". I would recommend doing that to yours if you want it wider rather than changing your entire dash.
Originally Posted by dsraven View Post
hey, thanks for the reply guys. i checked out the extended cab build thread. man that is a lot of fitting. Are you planning on pancaking the hood? always wanted to see one of those old trucks with a pancake job. looks pretty cool so far.
soooo, i guess I will have a 58 chevy cab, with a 57 gmc dash and front clip. could be worse. i just love that gmc front end, and I plan on using a cluster from a 2001 chevy p/u, so the gmc dash would work better because the hump over the speedo is wider. dennis
