Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55 chev truck- s10 frame swap
Old 07-05-2007, 11:49 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
The S-10 chassis has the bow under the cab area which has to be dealt with..only way I know to do this is to set your cab on the S-10 chassis and then measure up for the mounts..You should have the fenders attached as well so you can line up the radiator support and the inner fender mounts..Once that is done the rest of it is straight up rod build..
Sam
