-   -   55 Chevy 4-speed Cross Member? (http://www.hotrodders.com/forum/55-chevy-4-speed-cross-member-80114.html)
tiresmoke55 01-29-2006 02:39 AM
HEY GUYS.
MY 55 CHEVY HAS A BUILT 350sbc BACKED WITH A 254 MUNCIE 4-SPEED AND IT STILL HAS THE OLD STYLE BELHOUSING WITH SIDE MOUNTS,,, ONLY THING THAT IS HOLDING MY TRANS IN IS THE DRIVESHAFT AND 4 BOLTS GOING 2 THE HOUSING. I NEED TO KNOW WHERE IS THE BEST PLACE TO BUY A NEW CROSSMEMBER FOR THOSE CARS PRETTY CHEAP OR WHAT KIND OF BRACE CAN I USE MAYBE FROM ANOTHER YEAR THAT WILL HELP SUPPORT THE TAIL SHAFT BEFORE I DROP MY TRANS OUT ON THE HIGHWAY 1 DAY LOL THANKS FOR ANY HELP DAVE :confused:
redsdad 01-29-2006 06:13 AM
http://www.danchuk.com/14_02_engine_...conv.html#1423
http://www.danchuk.com/10_01_transmi...mbers.html#767
You will need both unless the engine was already converted to side mounts.
302 Z28 01-29-2006 07:27 AM
Not having a crossmember was never a problem for us when we rodded 55-56 Chevy's in the sixties. My 56 had a stout 292 (283 over .060) with a Muncie 4 speed. I used to power shift the snot out of it and it never gave me any problems.
It is a simple matter to fabricate a trans mount out of tubular steel if you are so inclined. Please do not use angle iron however, it looks really tacky. If you decide to add a trans crossmember you may as well go ahead and convert to side mounts on the engine also.
Vince
