55 Chevy 4-speed Cross Member? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2006, 03:39 AM
tiresmoke55's Avatar
PO-BOYS-TOYS!!
Last journal entry: My new 55 chevy pretty sharp
HEY GUYS.
MY 55 CHEVY HAS A BUILT 350sbc BACKED WITH A 254 MUNCIE 4-SPEED AND IT STILL HAS THE OLD STYLE BELHOUSING WITH SIDE MOUNTS,,, ONLY THING THAT IS HOLDING MY TRANS IN IS THE DRIVESHAFT AND 4 BOLTS GOING 2 THE HOUSING. I NEED TO KNOW WHERE IS THE BEST PLACE TO BUY A NEW CROSSMEMBER FOR THOSE CARS PRETTY CHEAP OR WHAT KIND OF BRACE CAN I USE MAYBE FROM ANOTHER YEAR THAT WILL HELP SUPPORT THE TAIL SHAFT BEFORE I DROP MY TRANS OUT ON THE HIGHWAY 1 DAY LOL THANKS FOR ANY HELP DAVE
Old 01-29-2006, 07:13 AM
Will I ever get it done?
Last journal entry: Hood
http://www.danchuk.com/14_02_engine_...conv.html#1423
http://www.danchuk.com/10_01_transmi...mbers.html#767
You will need both unless the engine was already converted to side mounts.
Old 01-29-2006, 08:27 AM
302 Z28's Avatar
Not having a crossmember was never a problem for us when we rodded 55-56 Chevy's in the sixties. My 56 had a stout 292 (283 over .060) with a Muncie 4 speed. I used to power shift the snot out of it and it never gave me any problems.
It is a simple matter to fabricate a trans mount out of tubular steel if you are so inclined. Please do not use angle iron however, it looks really tacky. If you decide to add a trans crossmember you may as well go ahead and convert to side mounts on the engine also.
Vince
1959 Chevy shortbed fleetside Cross member removal rorourke Hotrodding Basics 11 12-03-2014 05:41 PM
55 Chevy Trans Cross Member mjanowski Transmission - Rearend 6 06-13-2012 10:50 AM
55 chevy cross member ???? tiresmoke55 Transmission - Rearend 9 04-15-2006 08:20 PM
57 Chevy auto trans cross member pikalpha Transmission - Rearend 7 12-09-2005 02:02 PM
