55 chevy bel-air rear axle swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2003, 07:47 PM
Post 55 chevy bel-air rear axle swap
I was told that I could put a rear differental from a 1970 to 1981 camaro into my 55 chevy bel-air. I would have to get larger u-bolts and have a bottom plate made to attach the shock. Has anyone done this ? Will the spring perches line up? Are the axles the same length? PLEASE HELP!!!
Old 01-18-2003, 12:32 PM
Post
G-Man, you can put the later rear end into your 55 Chevy as you were told. The plates you refered to are to mount the stock springs to. You only have to worry about where to weld the plates and can get the measurements from the old rearend. You will need to ensure you have the same pinion angle. Having said this, the new rearend is about 2 1/2" wider than the 55 so you will have to purchase wheels with the proper backspace so you can fit them into the wheel well. I am not clear about what you are refering to when you ask if the spring perches will line up. I am assuming you are using your 55 springs and are only going to attach the rear end to them.
Trees
