55 chevy disc brake set up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2006, 01:13 AM
tiresmoke55's Avatar
PO-BOYS-TOYS!!
Last journal entry: My new 55 chevy pretty sharp
am getting ready to install power disc brakes on my 55 chevy. where is the best place to get the kit or just the brake plates cheap? also i know i can use 69 camaro rotors and late model chevy calibers, what is the best size rubber line to use and can i still use inner and outer bearings for the camaro rotors or no? 1 more thing i would like to know, what all else is recommended to replace when doing a drum to disc change over? any help would be great! thanks alot Dave
Old 01-14-2006, 08:50 AM
56 Project's Avatar
Last journal entry: I've Changed My Project
I've got a 56 210 2 door. Just ordered parts from East Coast Chevy yesterday. One of the parts I ordered was a front disc power brake kit. I think that it was around $600. Comes with hubs, rotors, calipers, pads, lines, master cylinder, booster etc....... I've been saving up and had about $2300 order. 10% discount up to $1200 and then 15% discount plus items on sale dropped it to $1800.
Old 01-14-2006, 06:13 PM
HUH?'s Avatar
Tri 5 Disk Brakes
For stock spindles you need caliper brackets which are available lots of places. Speedway Motors and Ebay for example. The rest of the parts are standard OEM parts:
ROTORS
68-72 Chevelle or GM Equivalent
CALIPERS
79-86 Malibu or GM Equivalent (80's S10 Truck/Blazer, etc.)
BEARINGS & SEALS
A-6 Inner bearings
A-2 Outer bearings
7934S Grease seals
I have been researching the same thing for my '55 and found the info in the
1955-1957 ( Modified / pro street / show) bulletin board at ChevyTalk.com.
I reject your reality and substitute my own.
Old 01-14-2006, 11:03 PM
PO-BOYS-TOYS!!
55 chevy rubber brake lines
hello..does anybody know what kind of rubber line's to use when doing a drum to disc change over on my 55 chevy? thanks
Old 01-15-2006, 11:19 AM
56 Project's Avatar
They come with the kit from East Coast Chevy.
www.eastcoastchevy.com
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Attention: Willing to trade a *********for 55 buick or 48-54 chevy... DeathByGreaser Hotrodders' Lounge 5 10-23-2009 08:49 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
79 LTD disc Brake rearend Mike Pomerantz Suspension - Brakes - Steering 2 09-11-2003 11:19 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
