fuel pump installation
The 73 block should have a 3/8 threaded hole in the front of the block to hold the push rod up while changing the pump, if you install it before removing the old pump. There's a short bolt in most of the holes to prevent oil leaking out the hole. Remove it and install a longer one to hold the rod place. If you've already removed the old pump, hold the rod up and have some rotate the engine (by hand ) until the rod rises, then tighten the bolt to hold it up while you install the new pump. Don't forget to remove the longer bolt and replace it with the short one you remove.
| Fuel pump question | 7dcrzr | Engine | 2 | 01-24-2006 10:01 AM |
| Fuel pump buzz/oil sending unit question | schnitz | Electrical | 6 | 03-14-2005 08:52 PM |
| Fuel Pump recommend? | 71 Red Sled | Engine | 2 | 01-20-2004 06:27 PM |
| mech fuel pump question | Chevy_SS10 | Engine | 8 | 10-03-2002 07:52 AM |
| Question for Edelbrock Performer fuel pump owners | HotRodF100 | Engine | 1 | 07-20-2002 04:47 PM |
