55 chevy grounding - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2005, 07:09 AM
New Member
55 chevy grounding
What is the proper way to ground a 55 chevy? I have been told several ways. I have the straps , but want to do it right.
Thanks,
Bill Cherry
New York
Old 07-14-2005, 07:51 AM
302 Z28's Avatar
Body needs to be grounded to chassis. Engine needs to be grounded to both chassis and body. You can never have enough grounds IMO.
Vince
Old 07-14-2005, 08:39 AM
New Member
This is where I have had different comments--where do you ground the engine to the chassis and body?
Thanks
Bill Cherry
N.Y.
Old 07-14-2005, 09:31 AM
docvette's Avatar
Wiki Edits: 12
Grounding
Doc here,
The proper way to ground any vehicle, is run the Battery ground at or near the starter, then run a 10 gauge black wire from there to the firewall, and another from the Alternator ground lug, to the main grounding bolt at the block.
In addition to that obtain a 3 foot ground cable with ring terminals on both ends at the local parts house, run that from the main ground to the frame and secure.
For added grounds, obtain some ground straps with ring terminals on them, Install them between he hood and firewall, the fenders and frame, the doors and door posts, the trunk and main body.
Clean grease and burnish paint to bare metal, at all ground areas and use a star washer for each.
This system will operate flawlessly and last for years.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-14-2005, 09:35 AM
New Member
55 chevy grounding
Thanks Vince & Doc
Bill
whats the difference between 55 and 56 chevy pickup? mile-hightoyz Hotrodding Basics 8 08-13-2011 09:33 AM
55 chevy seat into a 61 chevy 61wagonair Interior 2 01-18-2005 05:19 PM
55 chevy hood measurements larry g Hotrodding Basics 1 11-28-2004 06:35 PM
55 chevy engine swap timrocket72 Engine 0 11-04-2003 09:33 PM
