55 chevy headliner rods ?
How many rods should I have? I have two with hooks,
in what order do they go.And how much space should I have between each one from front to back. Laura |
The bows could be different lengths. Measure between the mounting holes straight across, and then measure the bows the same way. They also could be color coordinated. The rubber grommet that holds the end of the bow could be colored to match one end of the bow. Check for tell-tale paint residue on the grommets and the ends of the bows. If you get the bows in their correct places, hold them vertical and measure between the bows to the center of the bows and add your seam allowance (usually 3/8 to 1/2 inch ) at each end. In other words, if the distance between the vertical bows is 15" , your fabric should be cut at 16 " assuming a 1/2" seam allowance. Be aware that at the ends of the bows you will need to curve the fabric to make up for the curve of the roof line whre it changes from horizontal to vertical. If you have never done this before, order a headliner to match your car. Good luck. Try www.kanter.com for headliners. Good luck.
55 Headliners never done it befor
Thank You
Never did it before,car Interior is something I always wanted to try. I worked at Woolrich back home, so I do know a little sewing but not this kind. This car is a basket case so it makes me even more into it just to see if i can |
If you need more help, you can send me personal messages, I will be glad to help if I can.
| Recent Interior posts with photos |
| whats the difference between 55 and 56 chevy pickup? | mile-hightoyz | Hotrodding Basics | 8 | 08-13-2011 09:33 AM |
| Attention: Willing to trade a *********for 55 buick or 48-54 chevy... | DeathByGreaser | Hotrodders' Lounge | 5 | 10-23-2009 08:49 PM |
| Installing headliner on a '55 Bel Air | switchblade327 | Interior | 9 | 02-29-2008 08:42 PM |
| 55 chevy 3 on the tree to a SBC 350? | mile-hightoyz | Transmission - Rearend | 8 | 02-23-2004 09:57 AM |
| 55 Chevy P/U Body Mount Question | bluesman123 | Body - Exterior | 0 | 02-15-2004 07:21 PM |
