55 chevy mufflers - not too loud - recommendations? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2012, 10:02 PM
bought a 55 with very very loud exhaust system from Dynaflow? I would like to have a much much more quiet ride. The 55 has a 350 engine with a "mild cam". any suggestions?
Old 04-01-2012, 10:25 PM
DoubleVision's Avatar
Yep. Go with Turbo Mufflers. Not only are they cheap, but they'll give it a deep tone at idle with acceptable loudness and are quiet at cruise.
Old 04-02-2012, 08:32 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
if you want nice and very quiet, i would go with one of the bigger magnaflows
Old 04-02-2012, 09:41 AM
I had Walker turbos on my camaro back in high school. It had a really odd resonance or drone at part throttle. It may have been a placement issue Your Mileage May Vary as they say.
Do you have tail pipes that go over the axle? Do you have a balance pipe?
My dad has cherrybombs on his 55 and he loves em. I hated em until all the packing fell apart. Walker and Heartthrob both make good quality turbo mufflers
Old 04-02-2012, 09:51 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i agree with DV, the dynomax turbo mufflers are pretty nice
here:
http://www.summitracing.com/parts/WLK-17733/
not sure what size pipe you have.
Old 04-02-2012, 11:10 PM
the tail pipes I think are 2.5,go over axil, r connected
the tail pipes are connected with the same size pipe.. before the mufflers
Old 04-03-2012, 03:31 AM
poncho62's Avatar
Wiki Edits: 5
I had to get hearing aids last year....The noise from my truck affected them (causes feedback)....I ended up putting a pair of stock NAPA mufflers on it. I work at NAPA so I could go into the muffler room and measure what I wanted. Ended up with a 23" muffler with 2 1/4 inlet and outlet....Nice and quiet. The parts guy said they can look up sizes, so they can match what you need
Also, if you put a balance pipe in your system it tends to quiet things down.
Old 04-03-2012, 06:20 AM
my87Z's Avatar
Then the mufflers I listed would be the right ones
290 Chevy Carb/ Intake Recommendations? AZ Willie Hotrodding Basics 7 02-22-2012 09:49 AM
Carb and induction recommendations, 408 Chevy.. Dilbert Engine 5 12-03-2008 01:15 PM
intake recommendations for 302 Chevy? hogggster Engine 9 01-02-2008 07:49 AM
Carburetor Recommendations Chevy 305 4bl maverick19642001 Engine 28 08-18-2007 06:14 AM
Chevy 383 - Heads and cam - recommendations? canter Engine 18 09-02-2005 04:29 PM
