55 Chevy no brake lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2013, 06:35 PM
Hello, all if a sudden I lost brake lights. Fuses are good and I just installed a new in line brake switch. Parking lights and turn signals work. Brake pressure seems to be the same as when they worked.
A
Has anyone run into this situation and have a cure?
Regards
Doug
Old 08-18-2013, 06:57 PM
brake lights
check for voltage on one side of switch, if switch is working when brake presure applied voltage should be on other side of switch,then check wiring to turn signal switch for voltage, if no voltage out to brake lights your problem may be all in your signal switch. hope this helps.
The Following User Says Thank You to carstechguy For This Useful Post:
Rexel123 (08-18-2013)
Old 08-18-2013, 07:05 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
TS switch
Using a test light, check for voltage at the fuse and (1) terminal of the brake light switch. When the pedal is pressed the brake light switch should show voltage at both terminals.
If they are working the next thing in this circuit is the turn signal switch. The brake light circuit feeds through the TS switch when not being used for the TS.
The TS and brake light fuses are separate.
vicrod
The Following User Says Thank You to vicrod For This Useful Post:
Old 08-18-2013, 07:14 PM
Brake lights
No voltage at the brake switch. am not very good with auto electrical. What would the turn signal switch have to do with the brake lights?
Thanks
Dug
Old 08-19-2013, 04:05 AM
EOD Guy's Avatar
As Vic mentioned above the TS switch interrupts the brake light feed when the TS is on and the Brake is applied. If you don't have pwr to your Brake switch..... is a pwr supply problem, most likely a fuse is blown.
The Following User Says Thank You to EOD Guy For This Useful Post:
Rexel123 (08-19-2013)
Front parking lights come on with brake lights valtiel43 Electrical 9 03-06-2014 04:55 PM
need wiring diagram for brake lights turn signals on 77 Chevy C30 truck mike 96 ws6 Electrical 5 09-04-2011 04:30 PM
1954 Chevy 1/2 ton pickup brake lights latebloomer Electrical 4 06-12-2010 09:49 AM
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 06:51 PM
58 Chevy Apache : Brake Lights / Wiring Harness Rathimis Electrical 3 12-13-2005 08:34 AM
