'55 Chevy Power Disc Master Cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2007, 07:24 PM
Last journal entry: Cab Bolted to Frame
I've done a search here and couldn't find the info that I'm looking for - what GM donor car should I look for to get a power master cylinder for my front disc brake swap on my '55 210? I'm tryimg to put together a low-buck swap using the stock spindles and adapter brackets for the small GM calipers.
Thanks,
Jim
Old 10-26-2007, 07:47 PM
302 Z28's Avatar
I like the 67 427 Corvette master cylinder. They can be had in just about any configuration from all power disc to manual. Some companies even make a master with outlets on both sides, you can use the side you need then plug the other. Also the Corvette master can be had almost anywhere, unlike some others.
Vince
disc brake conversion master cylinder Eric64 Suspension - Brakes - Steering 9 09-26-2006 03:19 PM
55 chevy disc brake set up? tiresmoke55 Suspension - Brakes - Steering 4 01-15-2006 11:19 AM
converting standard brakes to power on a 55 belair Randal4h Suspension - Brakes - Steering 5 09-15-2003 11:45 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
