Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55 Chevy QTR dillemma.
  #30 (permalink)
Old 04-13-2013, 01:15 AM
tech69 tech69 is offline
put up or shut up
Originally Posted by deadbodyman View Post
Ok,Heres something for you to try,just remember where it came from....
remember you were talking about welding a strip to help with doing a butt weld ?
try this on a long seam...
using drill screws screw a 1-2" strip in to help hold the butts in place and back up the weld but insted of steel use a copper strip....when your done unscrew the copper strip and BAM!!! you have a perfect straight butt weld because the copper sucks up heat and backs the weld....
................................................lu v ya 2....................
DBM
that's a great idea! I'm thinking it can work with metal too if you just do a few light tacks and then unscrew it and it would only need to be screwed on top, the bottom could be held down flush with a screwdriver while welding. Man I come up with good ideas! Just kidding. Thanks for that tip! The worry isn't the butt weld at all the worry is holding it up but that solves that. I came home today thinking "I'm just gonna get it done-screw it!" I'll tell ya why...
look closely
ying and yang aren't agreeing here
this was a good idea.
this wasn't. I should have made my second cut on top cause the top needs to be round anyways and skinnier and I could have rounded it easy by cutting and reshaping. Guess hitting one bird with a stone is good enough on this one so I might have to make two cuts or carefully hammer and dolly the top edge round. The bottom one not as important. Damn bumper doesn't hide it!
really? On this I will tunnel the top of the quarter...cut a slice and insert a piece of rounded sheet metal inbetween. It also needs to go out up top on the outside so that idea will work well.
