Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55 Chevy QTR dillemma.
  #35 (permalink)
Old 04-13-2013, 09:13 AM
MARTINSR MARTINSR is online now
Originally Posted by deadbodyman View Post
Ok,Heres something for you to try,just remember where it came from....
remember you were talking about welding a strip to help with doing a butt weld ?
try this on a long seam...
using drill screws screw a 1-2" strip in to help hold the butts in place and back up the weld but insted of steel use a copper strip....when your done unscrew the copper strip and BAM!!! you have a perfect straight butt weld because the copper sucks up heat and backs the weld....
................................................lu v ya 2....................
DBM
That is a great idea! If you butt it perfectly you don't need it, but if you can't, a long seam like that is pretty hard to make perfect, you can put the copper backing, BRILLIANT!
