Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55 Chevy QTR dillemma.
  #57 (permalink)
Old 04-17-2013, 07:13 PM
carolinacustoms's Avatar
carolinacustoms carolinacustoms is offline
Automotive Extraordinaire
Nice job there tech. If I ever do another quarter on a tri-five I had already decided to do something different than the one we recently changed. Looks like the way you cut and welded is the way to go. We changed the full quarter and bent the inner flange you were showing, It was a major PIA to get right. There is also a piece inside the quarter under that same flange (i guess for stiffining purposes?) that is a pain to change also. I also had the same problem at the tail light area that you did, and performed a similar fix. Looking good, keep up the good work.
Kelly
