55 chevy rear seat
can anyone tell me if you can use a rear seat out of a 4 dr. 55 chevy in a 2 dr. sedan??
thanks ej |
rear seats 210 vs. Impala/Belair
I'd have to add a note to this... the Belair version seats were the primere style prior to the Impala in 1958. The armrests in the Impalas were incroaching the rear seat, the Belairs had armrest mounted on the side panel. Please check some photo's.
You are correct, but the original question was whether the rear seat from a 1955 2 door car would fit in a 4 door car. The only difference in the seats was how they were upholstered, with the Bel Air having the fanciest upholstery of the three.
Very true. The question was about the rear seat and I got diarrhea of the mouth. I meant the front seats were interchangeable between the 2 door 150, 210, and BelAir, and between the 4 door 150, 210 and BelAir. I didn't say it right.
1955 Chev Rear Seat Frame Configuration Differences
EJ,
QUESTION, can anyone tell me if you can use a rear seat out of a 4 dr. 55 Chevy in a 2 dr. sedan?? I just ran into this same seat configuration issue. RESPONSE: The seat base frames are interchangeable, with one significant configuration difference. The 2d post rear seat base has square corners on the front edge The 4d post rear seat base has round corners. If you try to install a 2 door seat cover on a 4 door base frame, you will have 3-3 1/2 inches of unsupported cover material, at both front corners. NOTE: The rear seat, back frames are common between both 2 door and 4 door vehicles. The expert on this seat cover issue is Mr. Pete Ciadella, owner of Ciadella Interiors, Tempe, Arizona. R, C. Zink cnzink@yahoo.com |
The simple solution to this problem would be to add a piece of border wire at the front corners to square the frame off. This is a very simple fix. In the reverse situation, a round piece of border wire could be attached. Again, that would be a very simple fix also.
| All times are GMT -6. The time now is 07:37 AM. |
