Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55 Chevy Trans Cross Member
Old 06-11-2012, 02:31 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
The way it is now, there are 2 mounts at the front of the engine and 2 mounts on the bell housing.....I ran my 55 with those mounts for years without issue. If you add a cross member and leave the other 4 mounts, no problem, but if you remove the bell housing mounts, you should adapt side engine mounts. Its too long a distance from the front to that rear mount.
