55 chevy truck frame swap..pro & con's - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2013, 06:25 AM
Hi to all
any suggestions ? Anyone with info. would be great help.
I want to rebuild my 1955 (2nd series 3600)chevy truck with newer drive train.
Ive purchased a 1988 silverado 4x4 to use (good idea or bad?) I know some would rather i buy all new stuff but the 88 was $1500 and all seems to b in good working order.
O, by the way, I've never done a project this big before so i am a rookie! but i have what it takes....I hope..
Please feel free to respond ..with help or hender...Later
Old 03-04-2013, 08:24 AM
Wiki Edits: 27
frame swap
It all depends, how close are all the measurements and frame contour. I put a 48 jeepster on a Jeep Fc pug nose 4 X 4 with a chevy engine, That was easy, Kind of. the frame shapes were the same, the truck frame was longer in the front and back. , just 2 new body mount front brackets and a swap to a GM powere steering gear box. Later a swap of the Jeepster body to a chevy blazer chassis . That was A LOT of Work, we had to move the engine back 8 inches, new drive shafts, clutch and brake pedal relocation, neither gas tank fit, had to modify the floor, new shock mount crossmember etc. Always try to find one someone has done first to see how easy it would be. Mabe check out one of the chevy 4 X 4 truck forums,
google is your friend
1950 truck frame swap to 1980's chevy frame 1950truck Suspension - Brakes - Steering 25 01-24-2013 07:13 PM
55 chevy truck sub frame swap canopener General Rodding Tech 7 06-09-2009 07:42 AM
1/16 versus 5/64 piston rings:Pro's & Con's Guy Hiltz Engine 6 05-28-2008 11:45 AM
Gear Drive Pro's, Con's & Recomendations Willys473 Engine 1 04-18-2006 11:13 AM
Gear Drive Pro's, Con's & Recomendations Willys473 Engine 21 04-16-2006 04:20 PM
