Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55 Chevy Truck Rearend Ratios
Old 10-17-2006, 05:03 PM
DOUBLEDICK's Avatar
DOUBLEDICK DOUBLEDICK is offline
A truck t5 will work but the camaro is rated for up to 5000lbs that 55 is 6000lbs with you in the seat(I grenaded my camaro t5 in the 58).31x10.5 tires will help but the 235 wont turn much higher than 3.73 and the higher gears will hurt in town mileage as you will find yourself deeper into the gas pedal.
