55 Chevy Truck springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2010, 09:11 PM
Yellow55's Avatar
I just bought a 2nd series 55 Chevy 3100, Some one took the easy way and took out some leaf springs to lower the truck, now it rides down on the bumpers. Will it be better to find a set of used one from back in 55 or is there a better replacement with out raising the truck up to much.
My plans later are to put IFS system on but want to drive it a little before I take it apart.
Also I need a replace steering rod that will fit the ball end OEM steering arms or is there a better replacement for that as well?
Old 09-30-2010, 11:32 PM
WELCOME to Hotrodders.com
As a Moderator here, I want to be one of the first to WELCOME you here.
I had a 1955 Chevrolet 2nd series 1/2 ton pickup years ago and I also removed a few leafs. Mine almost touched the rubber bump stops. I cut MOST of the bump stop off ... because I liked the ride and the way it looked.
After I grew tired of the Chevrolet and wanted a 1956 Ford F-100 Big Window ... I sold the 55 Chevrolet to a friend. He wanted it raised up. I had thrown away the leafs I had removed so we found a used set of springs and replaced 2 or 3 ( been a long time ago ) leafs and the Chevy came up about 3/4 th to maybe 1 inch. It still rode good ... but he wanted it higher. So we installed all the stock leafs. It went up but the ride was rough and bouncy. He did not like it. So he sold the truck to another guy and the new owner installed a Camaro front clip.
Again ... WELCOME
DEUCE ... Moderator
Old 10-01-2010, 10:55 AM
DOUBLEDICK's Avatar
Deuce Welcome to the forums.The rest of us truck guys hang out in the hotrodders lounge.Check out the thread "55 to 59 chevy truck owners"Bring your lunch it is full of information and Ideas
55 chevy truck bed help bowtiebadboy Body - Exterior 11 09-30-2007 10:36 PM
55 chevy truck rear end swap Wildman Transmission - Rearend 8 06-11-2007 07:16 PM
Header choice for 55 chevy truck. Hickl Engine 1 07-07-2005 09:45 PM
How Hard Is It To Put A 440 In My 55 Chevy Truck? JFK Engine 7 06-03-2005 09:27 AM
2" drop Springs for 55 chevy belair? New2theart Suspension - Brakes - Steering 6 03-06-2004 06:11 PM
