55 chevy truck sub frame swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2009, 05:18 PM
have 55 chevy rat truck plan on using 78 camero front sub frame someone said this subframe is to wide dosen't seem right to me any body know for sure?
Old 05-07-2009, 06:16 PM
life is a temporary assignment
This is a 58 Chevy I did with a Nova front clip..Which is narrower then the Camaro.There's more pictures of this truck in my album..
ID:	38057   Click image for larger version
ID:	38058   Click image for larger version
Old 05-08-2009, 07:57 AM
reply
looks like a nice job so far. That is a interesting set up on the rear frame. I have a 64 short bed that I did 7 years ago with air ride on the rear using a 10 bolt posi narrowed with two ford short side axels aftermarket long panhard bar front and rear stablizer bars and a fat man bolt in mustang II front end the truck steers like a sport car I will send some pic as soon as i figure out this new camera. the latest project is a 55 short bed this will be a rat rod project and will be bracket raced as well the 64 has been runner up at the Rock and race three day meet and nostalga races and street eliminator several times as well I like to build em strong and run em hard. I am hope the camero sub frame is not to wide but Ialso have a nova but it has drum brakes and would have to be changed over but I suppose the camero brakes would fit the nova sub frame now that I am ret. I hope to have more time for these projects
Old 05-13-2009, 10:27 PM
techinspector1's Avatar
Wiki Edits: 326
Here's the front track of Camaros. Measure the front track (centerline of one front tire to the centerline of the other front tire) of your truck and make a decision.
58.7 -- 67-69 Chevy Camaro
60.4 -- 70 Chevy Camaro
61.3 -- 76-80 Chevy Camaro Z-28, Pontiac Trans Am TA
And Nova...
59.8 -- 68-74 Chevy Nova
Here's an alternative that seems to be popular...
58.5 -- 78-86 Chevy Monte Carlo, Malibu, El Camino, Olds Cutlass, Pontiac Grand Prix
Old 05-13-2009, 11:06 PM
these are hub to hub measurements...
58'' --78-86 Chevy Monte Carlo,Malibu,El Camino,Olds Cutlass,Pontiac Grand Prix.
61.5'' -- 76-80 Chevy Camaro Z-28, Pontiac Trans Am
60'' --- 67-69 Chevy Camaro
Here is a web site that may help you.http://www.quickperformance.com/Tech...us_measure.htm
Old 05-14-2009, 07:42 AM
55 chevy trk sub frame
thanks for the information I have a nova rear steer sub frame in my collection of priceless parts however after a 5 hour ride to look at the e-bay truck back in the hills of southern ohio hearing banjo music the last hour the truck was junk so the project is on hold
Old 06-06-2009, 08:26 PM
RODDER18's Avatar
Canopener, here is a pic of my 56. It has a 86 Monte Carlo sub frame. as you can see the front wheels sit in farther so it can be lower without rubbing as bad when turning. It is harder to do than the Camaro or nova front end but worth it if that is the look you want.
Name:	proj x 12 005.jpg
Old 06-09-2009, 07:42 AM
truck sub frame
picture of your truck looks good I will try to photo my 64 it sits about the same but Iused a fat man front end and air ride on the rear
'55-59' Chevy Truck Frame Clip w/G-Body? fasteddy51 Suspension - Brakes - Steering 64 08-23-2015 03:52 PM
48 gmc truck to s10 frame swap pioneer-auto Engine 1 06-03-2009 09:09 PM
Question on 49 chevy truck frame sevt_chevelle Body - Exterior 4 08-13-2006 02:42 PM
1950 chevy frame swap trott Hotrodders' Lounge 2 12-23-2002 10:26 AM
