55 chrysler ny bagged and 4 linked - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2008, 09:26 AM
4 linked and bad sway/ fishtailing
Need help with four link, while driving it feels as if the rear is fishtailing need help
Old 04-27-2008, 11:06 AM
Wiki Edits: 49
Moving to suspension forum.
Old 04-28-2008, 07:26 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Is this a triangulated 4link or do you have a Panhard rod?
http://home.earthlink.net/~whshope
Old 04-28-2008, 09:38 PM
4 link
yes triangulated 4 link, then I added a panhard bar to see if it would help.
nothing
Old 04-28-2008, 10:08 PM
life is a temporary assignment
Make sure your panhard bar is level at ride hight.The more it is level, the better it will feel. If you have triangulated four link,You shouldn't need a panhard bar.
Old 04-28-2008, 10:32 PM
4 link
I added it to see if it would help. Could Ibe getting driveshaft vibration with the wrong pinion angle which is making it feel as if my *** is shaking lol
Old 04-28-2008, 10:38 PM
The wrong pinion angle can cause a lot of weird issues.
It can be used as a tuning tool also for traction ( launch )
Offset of the pinion ( side to side ) can also cause problems.
Like already stated, you do not need a panhard bar ...
Old 04-28-2008, 10:41 PM
4 link
Thanks will work on pinion and as for the panhard its not going to hurt having it in at this point will it?
Old 04-28-2008, 10:43 PM
4 link
One more thing does the placement of my airbags matter. they are placed on top of the axel?
Old 04-28-2008, 11:31 PM
powerrodsmike's Avatar
Wiki Edits: 161
A panhard bar with triangulated 4 bars or 4 links will cause a bind in the suspension.
Not good. Even so, if you added a panhard bar and it still feels sloppy, there are other issues.
How far apart are the links on the rear end and , what are they bushed with? Whose setup is it? A Chrysler New Yorker is a big car with a big overhang on the back, and would need some stout bars and ends and a fairly wide spread mounting position to keep things under control.
The airbags on top of the axle should not cause any problems like that..And driveshaft issues severe enough to make the car sway would have broken the driveshaft by now.
Can you take some pictures?
Later, mikey
BE different....ACT normal.
