55 ford 292 oil filter change over to spin-on - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2007, 07:52 PM
Last journal entry: done as of 9/10/08
need some help i took the oil filter off a 292 ford thunderbird engine and found a plate and under that is a oil filter diaphragm plate.
my question is do i need this diaphragm from what i can see in the parts book it is used for a canister type filter and the engine had a conversion kit on it along with the diaphragm. the kit i see in the parts book did not have this diaphragm.
can some one help me out?
thank you
rick
Old 07-20-2007, 03:45 AM
aka Duke of URL
I would play it safe and order a new kit because the gasket behind the plate is no longer serviced I believe.
Old 07-20-2007, 06:24 AM
thank you for the help,i have a new fiber gasket for behind the plate from the people that did the overhaul on the engine.
Old 07-20-2007, 12:30 PM
aka Duke of URL
It has finally dawned on me what you are describing (I am up in years). The origional diaphram plate should have been removed when the adaptor kit was installed. See thumbnails below;
Name:	Y-BLOCK Oil Filter Cannister.jpg
ID:	22836   Click image for larger version
Name:	B7A 6882-A_2.jpg
Old 07-20-2007, 04:09 PM
thank you that is what i was talking about, i am also up in years and don't always explain things to well.
again thank you for the help i will be back with more questions i am sure.
this board is the best everybody is so helpful.
rick
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Do NOT buy AC Delco Duraguard Oil Filters!!! indy_85stariones Engine 74 07-06-2009 02:19 AM
Oil Change recommendation. Everett II Hotrodding Basics 8 07-19-2007 08:39 PM
fram oil filter lower oil pressure elvis 66 chevelle Engine 33 09-14-2006 04:36 PM
Canister to spin on oil filter adapter? gavinpierce Hotrodding Basics 3 04-27-2006 06:12 PM
Engine never the same after a Fram oil filter JamesRS Engine 18 05-02-2005 10:27 AM
