55 Ford Car Engine Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2006, 05:20 AM
Sweet-34's Avatar
Lost In The 50's
Found two nice Customline Fords. They both have 6 Cylinders. One has an automatic the other a 3-speed. I want to put in a V-8. If I use a 272, 292, or a 312 Ford, Is this an easy swap? How about motor mounts and front crossmember? Will the V-8 bolt up to the automatic and the stick from a 6 cylinder car?
If I can't locate the Ford motors, how about a small block Chevy/Turbo 350 swap. Do they make mounts for this swap? Is there welding involved?
I want to build a rat-rod to cruise when I'm not showing my Sweet-34. All input would be greatly appreciated. Maybe you know of a Customline with a V-8 For Sale!!!!
Thanks...............Sweet-34
Old 03-14-2006, 06:24 AM
aka Duke of URL
The Y-BLOCK is a bolt-in. The manual six cylinder 3/S is a light duty and may not hold up to a 312. The automatic will fit with correct bellhousing, etc.
AAAAAAAAAAIIIIIIIIIIIIIIEEEEEEEE!!!!!!!!!!
...thud...
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
pre 87 car with post 87 engine swap? 84Z Engine 6 05-12-2004 10:13 PM
2001 Ford SOHC 4.0L V6 engine swap metrobill Electrical 10 02-20-2004 08:15 AM
engine swap 5.0L / 51 ford truck hubcap Hotrodders' Lounge 2 09-23-2002 09:04 PM
