55 Nomad drip rail repair or replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2002, 11:12 AM
New Member
Post 55 Nomad drip rail repair or replacement
I have a really nice 55 nomad. However I am getting some rust problems on the drip rails ond just above them on the top. Does anyone offewr patsh panels for this problem? Or does anyone have any suggestions on the proper repair or replacement of the drip rails?
Thanks! Nomaddaddy
Old 09-08-2002, 08:08 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
I'm not sure if a patch panel is offerd, but i doubt it. The thing I have always done is you break out the welder and sheetmetal and a hammer and patch it with old fashion engineering. If you need help with this process just ask, more than happy to help.
HK
Old 09-14-2002, 10:47 AM
New Member
Post
that sounds like a bettere way than what i did i cut the rusty things off and welded them up look good but was a hell of a lot of work
Old 09-14-2002, 05:49 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
Thumbs up
Just out of curiousity (or however its spelled), is this car customized? If so, have you thought about shaving the drip rails completely? You can do it in the same manner as HK suggested.
Old 09-20-2002, 10:07 AM
bullheimer's Avatar
NEVER use credit cards!
Post
unless it's all original i'd shave them, but i don't know how hard it would be but seems like it's easier than fixing them
what i did to my truck, was before any rust, was i got a screwdriver and dug out all that putty crap, then i wire wheeled it, then i mixed up some glazing bondo and put a nice smooth fillet in there with my finger and after than primered and painted it with black -high solid-paint to keep the water out. looks great from above and will never rust again
[ September 20, 2002: Message edited by: bullheimer ]</p>
55 Ford Crossmember Replacement Sweet-34 Suspension - Brakes - Steering 9 04-07-2009 12:07 PM
drip rail??? hmmmmm jcillch Body - Exterior 4 10-21-2006 04:44 AM
PANEL REPLACEMENT 55 chevy DONZIE Body - Exterior 2 10-28-2005 03:30 PM
55 chevy hood hinge repair mad55chevy General Rodding Tech 5 03-21-2004 11:10 AM
drip rail replacement charlesjonas Body - Exterior 2 04-10-2002 12:08 PM
