55 Rearend swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2006, 09:09 PM
55 Rearend swap
What 10 Bolt rear ends fit a 55 Chevy?
Without narrowing. Measure 60 inches out side of hub.
Old 11-04-2006, 09:31 PM
poncho62's Avatar
Wiki Edits: 5
A Nova rear is about the same width.
Why do you want to switch...I prefer the 55-64 rears.
Old 11-05-2006, 05:29 PM
tmeyer's Avatar
10 Bolt Rear End
I have a 10 bolt in my 57 pickp. It is from a Gen 2 camaro which is 60.5" wide. I wanted a 10.5 " since they are stronger then a 10.2". The reason I changed my rear end from the original was so I could get a rebuild kit, posi traction, and 373 gears.
Take a look at this site for a grear reference:
http://www.quickperformance.com/Technical Info/sus_measure.htm
I also went with TCI's leaf spring upgrade kit. Check out my home web site for pictures of my project.
rearend swap for a nova nova63and66 Transmission - Rearend 10 11-10-2005 06:34 PM
rearend and axle swap Suckingas Transmission - Rearend 1 03-03-2004 05:37 PM
55 chevy engine swap timrocket72 Engine 0 11-04-2003 09:33 PM
1969 Camaro Rearend Swap josh7681 Transmission - Rearend 8 01-02-2003 02:44 PM
