55 stuck in reverse-any ideas - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2007, 11:49 AM
Slickriffs's Avatar
Took the truck down the backyard to dump the body..I backed in and it's stuck in reverse now
55 3/4 ton4 speed on the floor-original
Any tricks to get this out of reverse?
Thanks,
Keith
Old 05-27-2007, 01:30 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Can you rock it with pressure on the shifter (engine off), maybe by bumping the starter? Sounds like you may be on an incline and the clutch isn't completely releasing...
Old 05-27-2007, 01:50 PM
T-bucket23's Avatar
Wiki Edits: 26
Worn shifter linkage. Sometimes goofing with the shifter will free it
Old 05-27-2007, 03:16 PM
Slickriffs's Avatar
Geeze the tranny's only 52 years old..
Well it's fixed for now..took an axe...sounds
scarey huh? And tapped the shifter 3 times with
the bunt end and in moved to neutral..Seems it
needs a jolt rather than a lot of steady pressure..
Guess I'll throw a new tanny on project list..might
be a good excuse to go automatic?
Thanks for the suggestions gents
Happy Memorial Day
Keith
Car Will Not Go Into Reverse?? HotRodMan Transmission - Rearend 15 05-22-2007 02:33 PM
No reverse after Overhaul SG2nite Transmission - Rearend 9 10-31-2004 03:52 PM
TH700R4 No reverse! dope_pm5k Transmission - Rearend 6 08-26-2004 12:50 AM
ford aod reverse shift snoman Transmission - Rearend 2 02-17-2004 06:38 PM
350tranny. no reverse. Sonkey Transmission - Rearend 3 02-11-2004 11:31 PM
