'55 T-Bird 12 volt conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2006, 06:47 AM
Sidn's Avatar
First, I'll start with the basic vehicle information, and then I'll proceed with my current problem. My apologies, but this is probably going to be rather lengthly.
Car - '55 T-Bird
Engine - stock 292
stock distributor
stock generator
6-volt positive ground
Converted to 12 volt -
new generator, (12 volt)
new voltage regulator (12 volt)
new ignition parts, coils, condenser, resistor installed (same distributor and plug wires)
all new 12 volt bulbs etc
I don't think I missed anything.
Now to my problem!
I have started and run this car after the 12 volt conversation for short periods (maybe 5 to 10 minutes) with no negative results - until last night.
I put in a brand new 12 volt battery - started the car, drove it down the lane and back - a few hundred yards.
When I shut it off, I noticed the 'generator' light was 'glowing' slightly. (this car has idiot lights only for gen and oil). I immediately disconnected the battery, and there was a very large spark, like a direct short circuit.
I double checked to ensure that I did not have anything like lights turned on, and reconnected the battery, and again, a very large spark. I could hear the voltage regulator making a noise when I reconnected the battery, so I disconnected the regulator, and the spark was eliminated.
However, it didn't make sense to me why I never had this problem over the past few months. So, I hooked up the regulator again, and then connect the battery, and no spark.
Then, I tried to start the car, and NOTHING! I turned the ignition swith to the 'start' position, and absolutely nothing happened - no solenoid clicking noise - nothing. But when I 'jumped' from the solenoid, it fired up right away.
I then removed the battery cable, and everything seems normal in that area - no spark.
I indicated at the beginnig that it was a 6 volt POSITIVE GROUND should that still be the case for a 12 volt system?
If not, then could that be my problem, but why didn't it act that way right from the very beginning?
I thank all of you in advance for your assistance!
Sid
Old 08-29-2006, 07:39 AM
You should try, http://disc.server.com/Indices/5173.html or www.y-blocksforever.com There are some very friendly guys that know ton's about the older fords and up-dating them. one in particular is "Hoosier Hurricane" His name is John and has several T-birds and is very knowledgeable.
Give them a try
Gary
PS. Ive got a 57 bird but went with a alternator.
Old 08-29-2006, 08:43 AM
Sidn's Avatar
'55 T-Bird
Thanks, glrbird - I'll give them a try!
Old 08-29-2006, 08:57 AM
aka Duke of URL
No...It should be 12V NEG GRD.
Old 08-29-2006, 09:03 AM
Sidn's Avatar
'55 T-bird
Thank you KULTULZ!
I appreciate the input.
Sid
6 volt to 12 conversion ed keeley Electrical 1 03-19-2006 03:24 AM
6 volt to 12 volt conversion? ajcedar Electrical 7 03-09-2006 06:16 PM
50 Ford 6 to 12 volt conversion JBGTO Electrical 2 02-17-2006 07:19 AM
6 Volt or 12 Volt 2000jack Electrical 2 02-09-2006 08:02 PM
12 volt conversion joellaz Electrical 2 09-25-2005 07:35 PM
