Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 555 bbc dart build cam choice
Old 06-04-2012, 12:15 PM
CNC BLOCKS NE CNC BLOCKS NE is online now
CNC Blocks Northeast
Originally Posted by dav770431
400 block i bought was trashed according to machine shop. Decided to go with a 454 but couldnt find a decent 4 bolt 2p rms short block. After talking to machine shop and several people they said with the money you would pay for the bare block you want with all the internals and then all the machine work you might as well buy a dart short block with more cubic inches and better quality block. So i went ahead and bought the 555 short block. Now just trying to decide the set up. ive decided on the heads, intake, carb etc but i was just trying to get advice on the cam. Uncle says the 680 lift solid roller is a good match but dad says it might be a little much so just wanted to see what you guys thought. Yes it will be a street and strip car. I wanted the cam a little more on the street side of things.
Make sure you measure every lifter for roundness and straightness and size and make sure the bore clearance does not exceed .002, I have been finding alot of lifters .841 and in an .844 lifer bore that .003 is way to much clearance.
