Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 55mph, 700r4 went neutral, Pump?
Old 09-23-2012, 09:35 AM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
I would suggest a close look at the converter drive hub. When the pump rotors break, the end of the converter hub will get buggered up some as the engine runs
