56 3100 C notch frame. Is in necesarry? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2013, 02:44 PM
So is it necessary to c notch the frame when flipping the rear axle on top of the springs on a 56 chevy pickup 3100? I plan on using the stock leaf pack and shackles. I have already tore it apart and without the weight of the cab, bed, etc.... I cant really get an accurate measurement to see how it will sit. Any help is greatly appreciated.
Old 12-04-2013, 06:05 PM
In most cases, yes. You will only have about an inch of up travel.
Old 12-06-2013, 05:13 PM
Here is a picture of one with air bags I did about a year ago. You can see the C notch, about 2", on the right side of the frame. The suspension is the stock springs, with only two leaves left, and a Caltracs type of traction bar.
Possible frame alternative for 51 Chevy 3100 HooahSarge General Rodding Tech 10 06-17-2011 04:13 PM
Frame Notch&Rear rail repair nawlins-tim Suspension - Brakes - Steering 1 08-17-2010 06:41 PM
g body frame notch sheldonw Suspension - Brakes - Steering 2 03-14-2008 08:37 PM
"C" notch vs. Squared notch vs. no notch cboy Suspension - Brakes - Steering 24 02-27-2007 08:58 AM
which frame for 1954 3100 pu chadg Hotrodding Basics 3 09-30-2006 12:45 PM
